Indy Mod man six pack setup #1712254
12/18/14 03:14 PM
12/18/14 03:14 PM
KY
9
95Kota408 Offline OP
KY
I am trying to set up my six pack after I get back from my deployment to the Middle East. I am going to start ordering some parts (carbs, spacers,Promax metering plates,ect...) I was looking at the Holley 440 carbs from summit and was wondering if there is better options out there? Below is what I have so far. Please help point me in the right direction.
408
Block was honed with Torque Plates
Align Honed
Square Deck
Scat Forged Crank
Scat Forged I Beam Rods
AutoTec Forged pistons
Eddie Heads fully ported
2.02 Ferrea Competition Plus intake valves 5/16'' stem
1.60 Ferrea Competition Plus exhaust valves 5/16'' stem
C.H.E. Precision valve guides
T&D shaft mount roller rockers 1.7
Crower Lifters
Cam 242/250
112 LSA
Lift IN EXH
.621 .621
Innovators West Damper
Moroso Oil Pan
Indy mod man six pack
Re: Indy Mod man six pack setup [Re: 95Kota408] #1712255
12/18/14 03:16 PM
12/18/14 03:16 PM
KY
9
KY
Pic #2
Re: Indy Mod man six pack setup [Re: 95Kota408] #1712256
12/18/14 03:27 PM
12/18/14 03:27 PM
Ohio
lockjaw-express Offline
Ohio
Very nice engines!
I am interested in the responses you get on the carb recommendations, too.
BR, Mark
Re: Indy Mod man six pack setup [Re: lockjaw-express] #1712257
12/18/14 08:18 PM
12/18/14 08:18 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Yes, look for the old DC mechanical 6 PAC setup that outflows the stock setup by about 200 CFM's and also you won't need to buy metering and base plates. My setup rocks .. just getting a wide band this winter to dial it in next spring! Here is all the info and the rebuild. Good luck!
http://www.forabodiesonly.com/mopar/showthread.php?t=275946&highlight=4782+4783
Re: Indy Mod man six pack setup [Re: ademon] #1712258
12/18/14 08:31 PM
12/18/14 08:31 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I'd really like to see how this engine runs with the mod man! Are you using a auto or manual ? I think the auto is more forgiving with a mechanical setup, I can floor it with no bog or stumble. I'm running a 9.5" dynamic that flashes at 4,400 rpm. The carbs usually go for around $800 or so in good used condition if you can find them. Keep us posted!
Re: Indy Mod man six pack setup [Re: 95Kota408] #1712259
12/19/14 02:05 AM
12/19/14 02:05 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
446ci indy sr,s maxwedge port
1.39 9.85 - 137 mph
Re: Indy Mod man six pack setup [Re: ademon] #1712260
12/19/14 02:11 PM
12/19/14 02:11 PM
KY
9
KY
I started looking for the Direct Connection carbs. I bet this is gonna be like finding a needle in a haystack. If you guys know anybody who might be selling some let me know.
Re: Indy Mod man six pack setup [Re: 95Kota408] #1712261
12/19/14 03:23 PM
12/19/14 03:23 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I've seen a couple sets for sale in the last year or so, you should be able to find a set. I think these carbs are your best bet performance and price wise, I'm very happy!!!
Re: Indy Mod man six pack setup [Re: ademon] #1712262
12/19/14 03:27 PM
12/19/14 03:27 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Car started and ran great right from the start, No springs, metering plates, base plates to change out or modify!
Re: Indy Mod man six pack setup [Re: ademon] #1712263
12/19/14 06:29 PM
12/19/14 06:29 PM
KY
9
KY
Not sure yet about a auto or manual. I am car shopping right now for something to put this thing in.
Re: Indy Mod man six pack setup [Re: 95Kota408] #1712264
12/20/14 12:35 AM
12/20/14 12:35 AM
Breckenridge, Texas
B-ridge Chally Offline
Breckenridge, Texas
TMP carbs sells a ford mechanical setup similar to the old DC carbs.
Re: Indy Mod man six pack setup [Re: B-ridge Chally] #1712265
12/20/14 10:30 AM
12/20/14 10:30 AM
KY
9
KY
I am planning on using this on the street 95% of the time. A lot of people say use vacuum secondary carbs on the street? Will the mechanical secondary carbs have decent street manners? What are the pros and cons of both?
Re: Indy Mod man six pack setup [Re: 95Kota408] #1712266
12/20/14 10:50 AM
12/20/14 10:50 AM
Breckenridge, Texas
Breckenridge, Texas
With the progressive linkage , it should have good street manners.
Re: Indy Mod man six pack setup [Re: 95Kota408] #1712267
12/20/14 01:00 PM
12/20/14 01:00 PM
Moved to N.E. Tennessee
GomangoCuda Online work
GomangoCuda  Online Work
I have mechanicals (4782,4783) on mine. No problem on the street. You will have to make fuel lines and linkage unless the carbs you find come with them. I had to make 3/8" thick spacers to go between the carbs and the aircleaner for fuel line clearance at the front carb.
I have No idea how streetable the Modman intake is.
The Ford mechanicals are significantly smaller than the 4782 4783 carbs. Might work great on a small engine.
Barry Grant also made some mechanical carbs that were a lot smaller.
Re: Indy Mod man six pack setup [Re: GomangoCuda] #1712268
12/20/14 04:35 PM
12/20/14 04:35 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
On my setup I have what I think is the linkage these came with when ordered from DC/ hustle stuff. I have the outboards kicking in when the center is about 40% open. I can drive all day on just the center. On the expressway It will go to 75 mph or so with the center at that 40% or so. At that point you will feel the extra resistance in the pedal... Push a little farther and BOOM your flying !!! You can see the linkage better in that link I posted
