Re: Can you use a 440 water pump housing on a 400?
[Re: bordin34]
#1712251
12/18/14 02:56 PM
12/18/14 02:56 PM
Posts: 5,163 CT
GTX MATT
CT
Yes that is correct, they'll all interchange
[Re: CHADCLINE22]
#1712253
12/22/14 12:49 PM
12/22/14 12:49 PM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
the outlet change was year related not engine related... post 72 440s got same water pump housing than 400.
so go ahead, you can use either on any year, and simply match the radiator and steering pump brackets.
The only problem could be usen earlier block into a late body keeping late setup, since the earlier block doesn't have the provision for the steering pump bracket bolt.
