727 fluid capacity? #1712138
12/17/14 09:51 PM
12/17/14 09:51 PM
Santa Barbara, California
E
Edahlke Offline OP
Edahlke  Offline OP
E
Hi All,
I'm going to do a pan drop on the 727 of my 68 Charger to replace the gasket and filter.
I will of course run through the gears and measure the dipstick in neutral, but I was just wondering about how many quarts I will need to add after a pan drop?
Also, it's a pretty simple procedure I assume right? No gotchas?
Re: 727 fluid capacity? [Re: Edahlke] #1712139
12/17/14 10:50 PM
12/17/14 10:50 PM
I'd think several qts would get you close. I would check/clean the pan for debris (especially metal) and adj the band while you are in there/have access. I'd see what you have now for lever clearance (taking/keeping good notes is always a good habit) then adj it & also drain the TC is it has a drain plug. EDIT I hear the MP pan gasket is VG (& pricey). A person could consider a cheaper one & make sure the pan rails are good/surfaces brake kleened/crisscross torqued in multiple steps
Re: 727 fluid capacity? [Re: RapidRobert] #1712140
12/17/14 11:00 PM
12/17/14 11:00 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
If you aren't draining the converter put is about 4 quarts and then warm up and check in Neutral. fill to full line. But if you aren't draining the converter you are wasting your money to just drop and drain the pan and change filter. There is a big quantity of contaminated fluid left in the converter. At least spin the converter to check if it has a drain and if so drain the fluid too. Won't get all the gunk out but better than nothing.
Re: 727 fluid capacity? [Re: MoparforLife] #1712141
12/18/14 04:39 AM
12/18/14 04:39 AM
If you can drain the converter, all the stock OEM Mopar converters I've worked on and seen had drain plugs in them, then start with 6 quarts on the initial fill and add as needed, I like to get the cold fluid level between the add mark and full mark, never to the full mark when cold or cool You can add a 1/2 pint or a liitle more later to get it to the full mark when its hot
