Re: 727 fluid capacity?
[Re: Edahlke]
#1712139
12/17/14 10:50 PM
12/17/14 10:50 PM
RapidRobert
I'd think several qts would get you close. I would check/clean the pan for debris (especially metal) and adj the band while you are in there/have access. I'd see what you have now for lever clearance (taking/keeping good notes is always a good habit) then adj it & also drain the TC is it has a drain plug. EDIT I hear the MP pan gasket is VG (& pricey). A person could consider a cheaper one & make sure the pan rails are good/surfaces brake kleened/crisscross torqued in multiple steps
