90 degree adapter question ... #171174
12/19/08 09:51 PM
12/19/08 09:51 PM
beentheredonethat
AverageJoe Offline OP
beentheredonethat
Adapter to block I got a thick paper gasket in the kit - didn't know another gasket went under the bolt head, got a nylon looking one and a thick cork gasket same size that may be used elsewhere ? Just want to get the gaskets right.
Re: 90 degree adapter question ... [Re: AverageJoe] #171175
12/19/08 10:31 PM
12/19/08 10:31 PM
Pizza Bucket
snuggles Offline
snuggles  Offline
Pizza Bucket
I believe the thin one goes under the bolt head.thicker against the block.
Re: 90 degree adapter question ... [Re: snuggles] #171176
12/19/08 10:40 PM
12/19/08 10:40 PM
beentheredonethat
beentheredonethat
So the thick cork one goes over the bolt - between the adapter and the block ? I have two Haynes manuals as well as "How to Rebuild Small Block Mopars" and I got nuthin' as far as instructions.
Re: 90 degree adapter question ... [Re: snuggles] #171177
12/19/08 11:08 PM
12/19/08 11:08 PM
(or a copper one under the bolt head)
Re: 90 degree adapter question ... #171178
12/20/08 03:54 PM
12/20/08 03:54 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Thin gasket under the head of the bolt, thick cork gasket on the bolt between the adapter and the block. Tighten down snug or it will leak. Mike
Re: 90 degree adapter question ... [Re: mopars4ever] #171179
12/20/08 05:25 PM
12/20/08 05:25 PM
North Florida
RebelDart Offline
super street
RebelDart  Offline
super street
North Florida
Awright then - I'll re-do it, but I'm going to waste the paper gasket that goes between adapter and block when I pull it apart - can I use silicone only when I reinstall - or am I going to have to order another gasket ?
Re: 90 degree adapter question ... [Re: mopars4ever] #171180
12/20/08 05:26 PM
12/20/08 05:26 PM
you might get the fel pro(the large round one) gasket for this, it's thicker, clean the block recess well & use some gasket sealer(permatex #2 is my fav). Oil leaks aren't fun to redo
