Page 1 of 3 1 2 3
Cross tied main cap #1711695
12/16/14 10:25 PM
12/16/14 10:25 PM
Dandridge TN
Dabee Offline OP
Dabee  Offline OP
Dandridge TN
Anyone make cross tied main caps for 440?
Re: Cross tied main cap [Re: Dabee] #1711696
12/16/14 10:33 PM
12/16/14 10:33 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
There are some available if I can remember who makes them. In my opinion there isn't enough material in the right areas of a stock block to use the though
Keith
Re: Cross tied main cap [Re: Dunnuck Racing] #1711697
12/16/14 10:43 PM
12/16/14 10:43 PM
Dandridge TN
Dabee Offline OP
Dabee  Offline OP
Dandridge TN
I found them. Pro-gram makes them. That's what I was thinking, there isn't much material left after you machine the web out to install them. I think I'll go with the BCR girdle.
Re: Cross tied main cap [Re: Dabee] #1711698
12/17/14 01:20 AM
12/17/14 01:20 AM
Why do any of those patches? Why not buy a good block with cross bolt mains and be done with it? I've seen several different brands of crank girdles for BB Mopars, none of them make any sense to me, you are adding some stability from front to rear on the main studs, but those are not the problem on 440 RB motors, the main caps and main webbing are I say that and I'm the one that bought the aluminum main caps and ARP main studs from 440 Source last winter so a customer and freind could use a stock 440 block for a new 512 C.I. bracket motorbuild I did for him I offered him one of the 4.500 World iron blocks I have and he turned that down Your choice, if you have access to a decent 400 block, go that way
Re: Cross tied main cap [Re: Cab_Burge] #1711699
12/17/14 01:32 AM
12/17/14 01:32 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
slapping on a girdle to the oil pan rail and then adding spacers and long main studs is not a good solution. neither is removing the webbing to cross bolt the mains on a 440.
our kit is the only one on the market that also ties in the #5 cap. also the W shape of our cap helps distribute the loads across the entire web of the girdle.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Cross tied main cap [Re: Cab_Burge] #1711700
12/17/14 02:19 AM
12/17/14 02:19 AM
Dandridge TN
Dabee Offline OP
Dabee  Offline OP
Dandridge TN
Cab, I agree getting a new after market block is the way to go. I just haven't found one yet. This engine never goes over 6,000 rpm. It currently has 820 passes on it. It's getting freshened up this winter, so I figured whileI have it apart I'd stiffen up the bottom end. It's a 496, running 6.5 1/8 mile ETs in a 2800 pound car.
Re: Cross tied main cap [Re: Dabee] #1711701
12/17/14 03:22 AM
12/17/14 03:22 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Personally I am NOT a fan of the girdles. I can't see where they address anything in the weak area of the blocks, which is the webbing. On a stock block, if I MUST run one, I put alum caps on and call it a day
Monte
Re: Cross tied main cap [Re: Monte_Smith] #1711702
12/17/14 03:53 AM
12/17/14 03:53 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
As far as the topic goes I agree with with Monte's strategy and do the same myself on stock block deals.
I also do not think the Mega block is the answer to the problem so much either. I have seen plenty of cap walk and fretting on Mega blocks to not feel real comfortable with them either. I have personally killed two of them myself.
FWIW if the original poster wants a set of Mega block caps I have some if you want to give it a shot. But suggest the aluminum cap route.
Re: Cross tied main cap [Re: Al_Alguire] #1711703
12/17/14 10:13 AM
12/17/14 10:13 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
the girdle minimizes or eliminates cap walk depending on how severe it is. we don't use the main studs to tie the girdle down to the caps. also our caps fit snug with the bottom of the girdle after a little machining.
last year we even made a girdle for a prostock hemi that had cross bolted caps. so we redesigned the original caps to use a similar concept as our big block caps. so he had main studs, cross bolts, and a girdle.
even with the cross bolted mains there was still tons of evidence of cap walk on his hemi. he hasn't pulled the engine out yet and I'm hoping he sends me some pics of the bottom end when it gets freshened up. i'll keep you guys posted.
2574 Elliott Dr
Troy MI 48083
www.sdconcepts.com
www.bcrproducts.com
Re: Cross tied main cap [Re: Monte_Smith] #1711704
12/17/14 04:08 PM
12/17/14 04:08 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
Monte
I think the block webbing/saddle area would hold up fine if it didn't have the main caps tightly bolted to it, caps that holds ALL if the crank forces in check. To put it another way, it's the forces in the caps that stress the block saddles. Anything that significantly reduces motion of the caps will reduce stress in the saddles.
Re: Cross tied main cap [Re: @#$%&*!] #1711705
12/17/14 04:48 PM
12/17/14 04:48 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
I know all the theories and hear all the claims of how the girdles help...........I just don't buy it and don't use them. Doesn't make me right or wrong, just my opinion.
The cap and the webs are the weak link. You put a better cap on it, the webs take the brunt. You put a girdle on it, the webs STILL take the brunt. You put alum caps on and for lack of a better way to phrase it, the caps absorb some of the pounding. I think THAT works better and is the way I choose to do it. If the webs were thicker and had splayed caps like other motors, this would be a non issue. Unfortunately that is NOT the case and we have what we have. As AL said, even the cross bolted Mega block doesn't SOLVE the issue, but the block is better, has more meat, better metal, better cap and cross bolts........so it SURVIVES better, but is not FIXED. You are not going to FIX something that has a poor design without a total re-engineer. So your option is to crutch it and make it as good as it can be. With a skirted block, MASS is your option, since splayed caps aren't
Monte
Re: Cross tied main cap [Re: Monte_Smith] #1711706
12/17/14 05:02 PM
12/17/14 05:02 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
And boy do the mega blocks have plenty of mass. About 130# more I am told. You guys stop talking about them cap walking.
Re: Cross tied main cap [Re: Airwoofer] #1711707
12/17/14 07:51 PM
12/17/14 07:51 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
When I freshened my Mega block from the previous owner it showed a fair amount of metal transfer on the caps. We line honed it and rebalanced (58 grams out at each end). It's running a 4.500" crank that came from Indy many moons ago. Has a pentastar stamped in it. I have know idea where it was manufactured. I run BME rods and a Fluid damper so we'll see if it looks better during freshen-up.
Doug
Re: Cross tied main cap [Re: dvw] #1711708
12/17/14 10:29 PM
12/17/14 10:29 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I don't think a motor with 820 passes on it needs crossbolted mains or a girdle !!!
Re: Cross tied main cap [Re: Stanton] #1711709
12/17/14 10:33 PM
12/17/14 10:33 PM
Q
Quicktree Offline
Quicktree  Offline
Q
820 passes @ 6000 rpm is nothing...
Re: Cross tied main cap [Re: Quicktree] #1711710
12/17/14 10:44 PM
12/17/14 10:44 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
That would be like 410 @ 12000,,,,,,I'd call that good.
If you like drag racing, support your local track.
Re: Cross tied main cap [Re: Quicktree] #1711711
12/18/14 03:53 AM
12/18/14 03:53 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
The 820 passes, nor the rpm has anything to do with it. All that matters is the power level. This motor obviously doesn't make much of that, so the cap issue is really a non issue.
Monte
Re: Cross tied main cap [Re: Monte_Smith] #1711712
12/18/14 04:13 AM
12/18/14 04:13 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Monte
Or a cylinder head with a combustion chamber designed in this century that requires 10 deg less timing to make equal or more power.
Kevin
Re: Cross tied main cap [Re: Twostick] #1711713
12/18/14 12:48 PM
12/18/14 12:48 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
What is strange is the KB block has steel caps. Kinda the reverse of what Monte was talking about.
Re: Cross tied main cap [Re: Airwoofer] #1711714
12/18/14 02:19 PM
12/18/14 02:19 PM
dogdays Offline
dogdays  Offline
For the KB block the rest of the structure is aluminum, provides the "give".
R.
Page 1 of 3 1 2 3
