MP Master Cylinder - What is the Bore Size?
#1711567
12/16/14 06:44 PM
12/16/14 06:44 PM
Posts: 4,275 Morrow, OH
markz528
Morrow, OH
What is the bore size of a Mopar Performance P5249271 master cylinder?
Re: MP Master Cylinder - What is the Bore Size?
[Re: markz528]
#1711568
12/16/14 07:52 PM
12/16/14 07:52 PM
Challenger 1
Cincinnati, Ohio
1 1/32" from my quick research.
The part # that ends in 70 is a 15/16" bore.
[Re: Challenger 1]
#1711571
12/16/14 08:51 PM
12/16/14 08:51 PM
markz528
Morrow, OH
I searched pretty thoroughly before I posted and I found conflicting information. However it may very well be a 1 1/32" bore.
If it is, I wonder if it would be prudent to switch to 15/16" MC to improve my braking? Got the 10 3/4 inch Wilwood 4 piston caliper rakes all the way around, and at 140 mph and 3450 lbs braking ain't great.
Opinions?
[Re: J_BODY]
#1711576
12/18/14 04:35 PM
12/18/14 04:35 PM
Posts: 2,926 A shed in England
Tig
A shed in England
I got the 15/16 bore master from Dr. Diff. I love the feel of it. Wilwood fronts, drum rear....manual.
Same here, changed from the mopar large bore master cylinder. Much improved
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#1711577
12/19/14 01:18 AM
12/19/14 01:18 AM
markz528
Morrow, OH
What do I mean by poor braking - I hit the pedal and the car slows but it just is like the brakes are fading. Does not feel like a lot of grab.
I have been running these brakes for about 15 years and the pads and rotors are original (not a lot of runs in that time period). Perhaps it is time for new rotors and pads - the rotors have some grooving - not sure if that is affecting braking or not.
However, I also question if a 15/16 inch MC might not be an appropriate upgrade.
I do have the Doc 15/16" MC in my 67 Coronet street car with 73 Duster discs up front and 10 1/2 drums in the rear. The braking stinks - currently trying to figure that one out. I can lock up the rear brakes pretty easy on dry pavement so the issue has to be in the front.
[Re: markz528]
#1711578
12/19/14 01:49 AM
12/19/14 01:49 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Do you have a adjustable prop valve on the 73.. if you do which line is it on, front or rear.. is the pedal hard to push with very little movement to the pedal... if you go with a smaller master the pressure will go up but the pedal will travel farther
