Lower rear shock plate 1970 RR 440+6 with Dana #1711538
12/16/14 06:17 PM
12/16/14 06:17 PM
ONTARIO,CANADA
70RRINVIOLET6PAK Offline OP
ONTARIO,CANADA
Is the lower rear shock plates for a 1970 Road Runner 440+6 4 speed with a Dana rear natural finish or painted?Are they also date coded and do they they have a part number stamped in them and/or any other markings.Thanks Bob
Re: Lower rear shock plate 1970 RR 440+6 with Dana [Re: 70RRINVIOLET6PAK] #1711539
12/16/14 06:49 PM
12/16/14 06:49 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Bare steel finish. No date code. But does have a part number
Re: Lower rear shock plate 1970 RR 440+6 with Dana [Re: gtx6970] #1711540
12/16/14 08:10 PM
12/16/14 08:10 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
And they are the same as a 8 3/4.
Re: Lower rear shock plate 1970 RR 440+6 with Dana [Re: 62maxwgn] #1711541
12/16/14 11:37 PM
12/16/14 11:37 PM
Land of 10,000 Lakes
44D6PAKCUDA Offline
44D6PAKCUDA  Offline
They did have long ones and short ones(lower shock mounting stud) or was that just an E body thing?
