Who makes 70 Challenger inner fenders w/correct details #1711460
12/16/14 11:46 AM
12/16/14 11:46 AM
Highgate Falls, Vermont
manyc Offline OP
manyc  Offline OP
Hey Guys,
I posted this message at another forum and ended up with dead air so I thought I would give you guys a try:
I need to replace the inner fenders on my 70 challenger and would like to buy ones with correct details so that I don't have to modify them. The only repos that I can get a real picture of are AMD (attached) and they have 71-74 details (bump out on LH for battery hold down, indent for breather/fuel line on RH). I've seen repo inner fenders with the correct details on other member's projects, but I don't know who the manufacturer is. Goodmark ? Dynacorn ? I will also need to know who to buy them from.
Please PM me if you don't want to reply directly. I know that forums are sometimes touchy when it comes to mentioning one vendor over another.....
thanks Chris
If I can't fix it, I'll fix it so no one can !
Re: Who makes 70 Challenger inner fenders w/correct details [Re: manyc] #1711461
12/16/14 12:49 PM
12/16/14 12:49 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
the 71-4 style is all that's available repro AFAIK, either modify the areas, or look for NOS/used
Re: Who makes 70 Challenger inner fenders w/correct details [Re: DAYCLONA] #1711462
12/16/14 02:00 PM
12/16/14 02:00 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Believe that Goodmark makes the 70 E fender wells and AMD makes the 71-4 wells.
http://www.goodmarkindustries.com/p-12191-inner-fender-rh-70-74-e-71-72-b-2120-350-70r.aspx
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Who makes 70 Challenger inner fenders w/correct details [Re: moparmarks] #1711463
12/16/14 02:02 PM
12/16/14 02:02 PM
moparmarks Offline
moparmarks  Offline
Also the left well with the hump for the battery hold down is 72-4. 71 doesn't have the hump.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Who makes 70 Challenger inner fenders w/correct details [Re: moparmarks] #1711464
12/16/14 05:57 PM
12/16/14 05:57 PM
California City, CA
dart440 Offline
dart440  Offline
California City, CA
Late 71's also have the hump. Some have the threaded nut, others do not. Not sure when the cutoff was...
When you work on Spaceships for a living, how bad can a workday be?
Re: Who makes 70 Challenger inner fenders w/correct details [Re: dart440] #1711465
12/16/14 08:44 PM
12/16/14 08:44 PM
moparmarks Offline
moparmarks  Offline
I have owned and worked on a ton of 71 B and E bodies and never had one with the hump including one built 7/71. I also had a 72RR built 8/71 that didn't have the hump either. It also had 71 front floor and 71 rear foot well floor too.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Who makes 70 Challenger inner fenders w/correct details [Re: moparmarks] #1711466
12/17/14 08:20 PM
12/17/14 08:20 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
What's the difference with the floors.
Re: Who makes 70 Challenger inner fenders w/correct details [Re: 71GTX471] #1711467
12/18/14 10:51 AM
12/18/14 10:51 AM
manyc Offline OP
manyc  Offline OP
Attached is a pic of a new AMD floor pan. It has the 72-74 details. The ones that I know of are the dimple in the hump for the shifter and the indent in the rib under the seat.
Re: Who makes 70 Challenger inner fenders w/correct details [Re: manyc] #1711468
12/18/14 11:32 AM
12/18/14 11:32 AM
moparmarks Offline
moparmarks  Offline
71 B/E floor
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Who makes 70 Challenger inner fenders w/correct details [Re: moparmarks] #1711469
12/18/14 11:34 AM
12/18/14 11:34 AM
moparmarks Offline
moparmarks  Offline
72 B/E floor. Has a couple humps behind the cross member where the 71 is flat.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Who makes 70 Challenger inner fenders w/correct details [Re: moparmarks] #1711470
12/18/14 11:36 AM
12/18/14 11:36 AM
moparmarks Offline
moparmarks  Offline
71B rear foot well pan.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Who makes 70 Challenger inner fenders w/correct details [Re: moparmarks] #1711471
12/18/14 11:38 AM
12/18/14 11:38 AM
moparmarks Offline
moparmarks  Offline
72-4B rear foot well pan
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Who makes 70 Challenger inner fenders w/correct details [Re: manyc] #1711472
12/18/14 12:29 PM
12/18/14 12:29 PM
B.C.
mk_ Offline
mk_  Offline
B.C.
Goodmark inner fenders I recently bought match the 70 model year nicely and are stamped crisp like OEM
Re: Who makes 70 Challenger inner fenders w/correct details [Re: mk_] #1711473
12/18/14 12:31 PM
12/18/14 12:31 PM
B.C.
mk_ Offline
mk_  Offline
B.C.
Left side 212035070L
Re: Who makes 70 Challenger inner fenders w/correct details [Re: mk_] #1711474
12/18/14 12:40 PM
12/18/14 12:40 PM
moparmarks Offline
moparmarks  Offline
I thought that Goodmark made them but I never use reproduction metal myself.
Also the right one is 70E only and the left one is 70-1E and 71B.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Who makes 70 Challenger inner fenders w/correct details [Re: moparmarks] #1711475
12/18/14 01:30 PM
12/18/14 01:30 PM
B.C.
mk_ Offline
mk_  Offline
B.C.
On the rear footwells floor pans, when did they change the most forward body plug hole from being recessed down to up?
Was it just the 70 model year that was recessed down?
Re: Who makes 70 Challenger inner fenders w/correct details [Re: mk_] #1711476
12/19/14 10:57 PM
12/19/14 10:57 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
Moparmarks tnx for the floorpan pics.but without being there N having someone point out the differences I cant see it.
Re: Who makes 70 Challenger inner fenders w/correct details [Re: 71GTX471] #1711477
12/19/14 11:05 PM
12/19/14 11:05 PM
moparmarks Offline
moparmarks  Offline
No problem.
71 has this bulge in the corner. 72-4 is flat.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Who makes 70 Challenger inner fenders w/correct details [Re: moparmarks] #1711478
12/19/14 11:06 PM
12/19/14 11:06 PM
moparmarks Offline
moparmarks  Offline
71 does not have these humps. 72-4 does.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Who makes 70 Challenger inner fenders w/correct details [Re: moparmarks] #1711479
12/19/14 11:08 PM
12/19/14 11:08 PM
moparmarks Offline
moparmarks  Offline
I have seen several early 72B/E that have the 71 front pan. Think they just used up the 71 pans before changing to the 72.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
