Who makes 70 Challenger inner fenders w/correct details
#1711460
12/16/14 11:46 AM
12/16/14 11:46 AM
Posts: 14 Highgate Falls, Vermont
manyc
Hey Guys, I posted this message at another forum and ended up with dead air so I thought I would give you guys a try:
I need to replace the inner fenders on my 70 challenger and would like to buy ones with correct details so that I don't have to modify them. The only repos that I can get a real picture of are AMD (attached) and they have 71-74 details (bump out on LH for battery hold down, indent for breather/fuel line on RH). I've seen repo inner fenders with the correct details on other member's projects, but I don't know who the manufacturer is. Goodmark ? Dynacorn ? I will also need to know who to buy them from.
Please PM me if you don't want to reply directly. I know that forums are sometimes touchy when it comes to mentioning one vendor over another.....
thanks Chris
If I can't fix it, I'll fix it so no one can !
Re: Who makes 70 Challenger inner fenders w/correct details
[Re: moparmarks]
#1711464
12/16/14 05:57 PM
12/16/14 05:57 PM
Posts: 406 California City, CA
dart440
California City, CA
Late 71's also have the hump. Some have the threaded nut, others do not. Not sure when the cutoff was...
When you work on Spaceships for a living, how bad can a workday be?
[Re: dart440]
#1711465
12/16/14 08:44 PM
12/16/14 08:44 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
I have owned and worked on a ton of 71 B and E bodies and never had one with the hump including one built 7/71. I also had a 72RR built 8/71 that didn't have the hump either. It also had 71 front floor and 71 rear foot well floor too.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: 71GTX471]
#1711467
12/18/14 10:51 AM
12/18/14 10:51 AM
manyc
Attached is a pic of a new AMD floor pan. It has the 72-74 details. The ones that I know of are the dimple in the hump for the shifter and the indent in the rib under the seat.
[Re: mk_]
#1711473
12/18/14 12:31 PM
12/18/14 12:31 PM
Posts: 657 B.C.
mk_
B.C.
[Re: mk_]
#1711474
12/18/14 12:40 PM
12/18/14 12:40 PM
moparmarks
I thought that Goodmark made them but I never use reproduction metal myself. Also the right one is 70E only and the left one is 70-1E and 71B.
