Re: sb engine location in abody
[Re: cermac]
#1711441
12/16/14 10:45 AM
12/16/14 10:45 AM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
When we did my car we moved the engine back far enough for clearance to the steering rack. Things you'll need to consider are the master cylinder and firewall. If you move the master to the floor and scrap the stock firewall you can set it back further but then the cowl can interfere with the induction system. You'll also need to move the seat back from a stock location for leg room. As far as my experience tells me moving the engine back 1" moves approx. 100 pounds to the rear axle. Does it make a difference in how the car works? Not really if the suspension system is working.
[Re: cermac]
#1711442
12/16/14 11:49 AM
12/16/14 11:49 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Also the height of the engine makes a difference.. if you raise it up its easier to transfer the weight.. the amount of torque you plan on will also make a difference where you want it.. big torque keep it low.. I like to put the back of the engine at the new knee loop.. that usually makes it 50/50 on a moly chassis (static weight with the driver)
[Re: cermac]
#1711444
12/17/14 10:35 AM
12/17/14 10:35 AM
Guitar Jones
How far back did u move motor in relation to front wheel centerline?
The #1 spark plug is right at the strut. The struts are mounted with 8* positive caster.
[Re: cermac]
#1711446
12/17/14 10:47 AM
12/17/14 10:47 AM
Guitar Jones
Thanks for help and ideas. Did u make headers?
Yeah, I bought I think 18 J bends and the collectors from Schoenfeld Headers. The flanges came from Heddman as did the port adapter plates.
[Re: Guitar Jones]
#1711447
12/17/14 10:56 AM
12/17/14 10:56 AM
Guitar Jones
Oh and the engine and drive line are offset 1/2" to the right for starter clearance. That probably wouldn't be an issue with a round tube frame though.
