Page 1 of 5 1 2 3 4 5
Magnum force suspension wtf! #1711350
12/16/14 07:50 AM
12/16/14 07:50 AM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
What a piece of f!!!!!ing crap!
Binds everywhere, not enough travel, cant turn the wheels enough as the r&p joints hits the lower control arms! But lets say you launch the car so susp raises then need to turn the wheels alot the joints can pass the control arms but then the control arm cant go back because the rack is in the way. That would cause the steering to lock and one side suspension lock. This is freakin dangerous!!!
It was on a car i bought and when i installed the wheels they are so far out the tires WILL hit the fenders. So i started to look deeper into it and found all this crap.
I will put up some pics so you can see what i mean.
I will also contact the a$$holes and see what they say.
Re: Magnum force suspension wtf! [Re: sshemi] #1711351
12/16/14 09:03 AM
12/16/14 09:03 AM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
I had one in my car for about 6 months. I had the same issues with the track width being wider than stock as well as the ride height. I was not happy with the K-frame.
Re: Magnum force suspension wtf! [Re: Bigcube] #1711352
12/16/14 09:38 AM
12/16/14 09:38 AM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
Im so glad i found this out before taking it to the track!
Its a serious accident waiting to happen!
I feel like charging them for murder attempt!
Re: Magnum force suspension wtf! [Re: sshemi] #1711353
12/16/14 11:12 AM
12/16/14 11:12 AM
Rudolph, Ohio
moparguy7074 Offline
Rudolph, Ohio
Bob'sProFab...
Re: Magnum force suspension wtf! [Re: sshemi] #1711354
12/16/14 11:15 AM
12/16/14 11:15 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
At least someone was able to bolt it to the frame lol.
The best one out there I've had personal experience with is AlterK by Reilly motorsports. I've been 172 with one and it was arrow straight. easy, and perfect to install, no bump steer even with only .060 toe, and butter to steer. On launch, I never felt the tires leave the ground, nor felt them return. Smooth, nothing like what it felt like before.
Re: Magnum force suspension wtf! [Re: dthemi] #1711355
12/16/14 12:57 PM
12/16/14 12:57 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
Pic
Re: Magnum force suspension wtf! [Re: sshemi] #1711356
12/16/14 12:58 PM
12/16/14 12:58 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
2 if i lift the front end the joint can pass the control arm.
Re: Magnum force suspension wtf! [Re: sshemi] #1711357
12/16/14 01:01 PM
12/16/14 01:01 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
But ofcourse it wont be able to return with the shaft in the way. Disaster!
Re: Magnum force suspension wtf! [Re: sshemi] #1711358
12/16/14 01:02 PM
12/16/14 01:02 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
Why i started to look over things.
Re: Magnum force suspension wtf! [Re: sshemi] #1711359
12/16/14 01:03 PM
12/16/14 01:03 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
X
Re: Magnum force suspension wtf! [Re: sshemi] #1711360
12/16/14 01:11 PM
12/16/14 01:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yeah those tires are way out there.. also the knuckle
on the rack looks to be at the end of its travel(angle)
right now... that thing does have some issues.. plus
the tie rod is either bent or its just a piece of
tube just to mock up the tie rod
Re: Magnum force suspension wtf! [Re: MR_P_BODY] #1711361
12/16/14 01:18 PM
12/16/14 01:18 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
Its bent:-(
Re: Magnum force suspension wtf! [Re: sshemi] #1711362
12/16/14 07:25 PM
12/16/14 07:25 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Its bent:-(
What a mess , it looks like the lower A arm is also bent ?
It appears to me that the rack should have been set up either up higher so the tirod passed above it , but then on full suspenison compression it would have hit the rack , or been a lot further forward ... or BOTH ????
What a poor design .
Re: Magnum force suspension wtf! [Re: JohnRR] #1711363
12/16/14 07:51 PM
12/16/14 07:51 PM
5th and plum
redmist Offline
redmist  Offline
5th and plum
Is that tie rod cut and welded??
A whole lota What the heck going on with that whole car.
Re: Magnum force suspension wtf! [Re: JohnRR] #1711364
12/16/14 08:13 PM
12/16/14 08:13 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
Its bent:-(
A arms are like that from mf.
If i could lower the r&p it would clear. But it would need to be a fair amount witch is not possible without redoing the k member.
Looks like if i switch sides on a arms and turn them upside down it would clear the steering. But i would need to weld in new shock mounts and realign the lower balljoint.
I feel like maybe its not worth messing with a crappy piece like this. Maybe if i get it running welds starts to break...
Re: Magnum force suspension wtf! [Re: sshemi] #1711365
12/16/14 08:29 PM
12/16/14 08:29 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I wonder if that rack is not what came in the kit?
Mopar to the bone!!!
Re: Magnum force suspension wtf! [Re: 72Swinger] #1711366
12/16/14 08:36 PM
12/16/14 08:36 PM
australia
charger410 Offline
charger410  Offline
australia
There's something not right for sure. I have a mf and don't have any of the issues your clearly having. I'm at work at the moment but I'll have more of a look when I get off. Here's pic of mine
Peter. Australian Charger, alloy block injected 410in, w9 na 9.03@148 leafs 3000lb
1967 barracuda 605 hemi Stage5 millennium 8.2@170
Re: Magnum force suspension wtf! [Re: charger410] #1711367
12/16/14 08:45 PM
12/16/14 08:45 PM
australia
charger410 Offline
charger410  Offline
australia
Sorry that was a bad pic
Re: Magnum force suspension wtf! [Re: charger410] #1711368
12/16/14 08:51 PM
12/16/14 08:51 PM
australia
charger410 Offline
charger410  Offline
australia
Tyres
Re: Magnum force suspension wtf! [Re: charger410] #1711369
12/16/14 08:53 PM
12/16/14 08:53 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
Definitely something wrong there. My M/F frontend doesn`t look anything like that. And mine is 10 years old. Somebody`s been modifyin`. Think I`d pull that one out!
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
