Re: Magnum force suspension wtf!
[Re: sshemi]
#1711351
12/16/14 09:03 AM
12/16/14 09:03 AM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
I had one in my car for about 6 months. I had the same issues with the track width being wider than stock as well as the ride height. I was not happy with the K-frame.
[Re: dthemi]
#1711355
12/16/14 12:57 PM
12/16/14 12:57 PM
Posts: 2,128 sweden
sshemi
sweden
[Re: sshemi]
#1711356
12/16/14 12:58 PM
12/16/14 12:58 PM
Posts: 2,128 sweden
sshemi
sweden
2 if i lift the front end the joint can pass the control arm.
[Re: sshemi]
#1711359
12/16/14 01:03 PM
12/16/14 01:03 PM
Posts: 2,128 sweden
sshemi
sweden
[Re: sshemi]
#1711360
12/16/14 01:11 PM
12/16/14 01:11 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Yeah those tires are way out there.. also the knuckle on the rack looks to be at the end of its travel(angle) right now... that thing does have some issues.. plus the tie rod is either bent or its just a piece of tube just to mock up the tie rod
[Re: MR_P_BODY]
#1711361
12/16/14 01:18 PM
12/16/14 01:18 PM
Posts: 2,128 sweden
sshemi
sweden
[Re: sshemi]
#1711362
12/16/14 07:25 PM
12/16/14 07:25 PM
Posts: 75,004 U.S.S.A.
JohnRR
U.S.S.A.
Its bent:-(
What a mess , it looks like the lower A arm is also bent ?
It appears to me that the rack should have been set up either up higher so the tirod passed above it , but then on full suspenison compression it would have hit the rack , or been a lot further forward ... or BOTH ????
What a poor design .
[Re: JohnRR]
#1711364
12/16/14 08:13 PM
12/16/14 08:13 PM
Posts: 2,128 sweden
sshemi
sweden
Its bent:-(
A arms are like that from mf. If i could lower the r&p it would clear. But it would need to be a fair amount witch is not possible without redoing the k member. Looks like if i switch sides on a arms and turn them upside down it would clear the steering. But i would need to weld in new shock mounts and realign the lower balljoint. I feel like maybe its not worth messing with a crappy piece like this. Maybe if i get it running welds starts to break...
[Re: sshemi]
#1711365
12/16/14 08:29 PM
12/16/14 08:29 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I wonder if that rack is not what came in the kit?
Mopar to the bone!!!
[Re: 72Swinger]
#1711366
12/16/14 08:36 PM
12/16/14 08:36 PM
Posts: 159 australia
charger410
australia
There's something not right for sure. I have a mf and don't have any of the issues your clearly having. I'm at work at the moment but I'll have more of a look when I get off. Here's pic of mine
Peter. Australian Charger, alloy block injected 410in, w9 na 9.03@148 leafs 3000lb
1967 barracuda 605 hemi Stage5 millennium 8.2@170
[Re: charger410]
#1711369
12/16/14 08:53 PM
12/16/14 08:53 PM
Posts: 866 Winnipeg ,Mb. CA.
chryco
Winnipeg ,Mb. CA.
Definitely something wrong there. My M/F frontend doesn`t look anything like that. And mine is 10 years old. Somebody`s been modifyin`. Think I`d pull that one out!
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
