Oil pump -replace between race motor rebuild??? #171115
12/19/08 08:25 PM
12/19/08 08:25 PM
Penna
70satelliteguy Offline OP
Penna
How often do you guy's replace your oilpump?
I have had my Melling high volume pump and bronze distributor shaft in the car for 2 years and 200 passes. Should I replace them or keep running them for another two years?? The shaft still looks like new!
Thanks Mike
Re: Oil pump -replace between race motor rebuild??? [Re: 70satelliteguy] #171116
12/19/08 09:43 PM
12/19/08 09:43 PM
God's Country Maryland
GODSCOUNTRY340 Offline
The only way to be sure is to take your pump apart and inspect it. Check for gouging in the rotor, case and end plate. Also use a feeler gauge and check the clearance between the rotor and cover. If there are a lot of scratches and nicks on the rotor replace it. Remember, oil goes through the pump before it gets filtered so it can be nasty looking.
Re: Oil pump -replace between race motor rebuild??? [Re: 70satelliteguy] #171117
12/19/08 11:13 PM
12/19/08 11:13 PM
Like every part in a race motor that gets used hard, inspect it carefully and if there is any doubt about it replace it. Keep in mind though that a proven piece that isn't broken shouldn't be fixed or replaced
Re: Oil pump -replace between race motor rebuild??? [Re: Cab_Burge] #171118
12/20/08 12:28 AM
12/20/08 12:28 AM
Toronto Ontario, Can
Glen440 Offline
Glen440  Offline
I just inspect the oil pump rotor to see if it needs replaced. in 200 passes and no hard crap through it, it would be ok. My last motor had 500 passes and broke and I put that oil pump on its backup for the last 200. My 511 ate an oil pump pretty quick cause something went through it. didn't make it to the bearings but ate the pump.
87 dakota 6.1 hemi
Re: Oil pump -replace between race motor rebuild??? [Re: Glen440] #171119
12/20/08 12:57 AM
12/20/08 12:57 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Whenever you freshen a motor ,Just use common sense
I have a friend, high buck operation races Super Comp and hits about 10 divisionals and 6 national events a year ..
Rolls down the road in a diesel pusher motor home with a stacker trailer ..
Only buys rods and mains every other year on a 632 Big Chief
I think thats dumb but, its his money so ..
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
