Re: Numbers matching question? 1968 Dodge Dart GTS
[Re: Scotts72Rallye]
#1711138
12/15/14 09:40 PM
12/15/14 09:40 PM
Posts: 75,071 U.S.S.A.
JohnRR
U.S.S.A.
A friend is seriously looking at a '68 Dart GTS 383 4spd car. Two things that concerned him was that the six numbers on the lower right corner of the fender tag don't match the last 6 numbers of the vin tag. Should these always match? And second, the numbers stamped on the 4spd matched up until the last number, it should be a 6 but it's a 9. The ownwer told him that he thinks "the production employee accidently held the stamp upside down". I've never been a numbers correct kind of guy so any help would be appreciated.
as said the numbers on the tag are the number stamped on the body which doesn't match the VIN on a 68. The Broadcast sheet is the only way to tie them together , though there may be something of some original dealership docs ?
As far as that last digit being off, totally possible, but the number stamps were held all together in one tool , they were not held separately. I assume the original block is not present? If the trans is wrong, then the engine would/should be also as they were stamped at the same time, with the same tool, by the same person.
[Re: JohnRR]
#1711139
12/15/14 09:55 PM
12/15/14 09:55 PM
Posts: 2,107 Third Stone from the Sun
Scotts72Rallye
Thanks for the response John! The present owner claims all numbers match so I'll pass the word on to my buddy about number stamp tooling.
1972 Dodge Challenger Rallye UNDER CONSTRUCTION
[Re: JohnRR]
#1711141
12/16/14 02:06 PM
12/16/14 02:06 PM
Posts: 2,042 colorado
savoy64
colorado
there are body production line numbers stamped on mopars----on some the front 6 digit number is on the radiator support in plain view and the matching rear number is hidden under the rubber gasket of the back window--near the package tray---these numbers match the data plate and the broadcast sheet----in some years the front number is moved to the area of cowl near windshield wiper motor----these numbers have nothing to do with the vin number....
[Re: savoy64]
#1711142
12/16/14 08:00 PM
12/16/14 08:00 PM
JohnRR
U.S.S.A.
Package tray was on earlier cars ... like a 64 Savoy ... 68 A/B body it was on the trunk rail under the weatherstrip, in 69 they changed it from the SO number to the partial VIN.
On cars that had it on the cowl it would have been the partial of the VIN as that started in 70 with the E body.
[Re: 6bblgt]
#1711146
12/21/14 07:20 PM
12/21/14 07:20 PM
Posts: 27,471 So Cal
autoxcuda
So Cal
1968 383 Dart: Engine & trans should match last 8 digits of VIN on dash Core support & trunk lip should match the last 6 bottom row of fender tag (S.O.#)
S.O.# (Shipping Order number) on fender tag & VIN don't match in '68
The SPD (Scheduled Production Date) on fender tag has to be appropriate for the VIN
Post or PM those 2 & I can verify that they are at least "appropriate" for that plant & date
A single digit error is possible.
Where are the rear S.O. Numbers on a Fastback 68 barracuda? Still the trunk? If so, what side?
[Re: 70 buzz]
#1711147
12/21/14 09:02 PM
12/21/14 09:02 PM
Posts: 1,028 NB, Canada
moparfan53
NB, Canada
Lot of owners will make that claim. If the stampings on the engine , tranny, radiator support don't match the vin forget number matching. My two cents
As already mentioned, the radiator support stamping will not match the vin on a '68 model year car, that started with the '69 models.
[Re: JohnRR]
#1711148
12/28/14 12:09 AM
12/28/14 12:09 AM
Posts: 664 Stuart, FL
Grassosgarage
Stuart, FL
I know on a '67 Charger the rear stamp was down by the holes for the bumper bracket. I have '67 Dart I can't find a rear stamping in the trunk jamb or rear bumper area. Any idea where it is on '67 A body?
'70 Cuda 440/auto '70 Duster 340/4sp project '70 Satellite convert 318 survivor
[Re: Rhinodart]
#1711152
01/02/15 09:32 PM
01/02/15 09:32 PM
Posts: 1,176 Woodbridge
Tommy The Chryco
Woodbridge
i understand the block and auto tranny would be stamped together, would that also apply to a 4sp bell housing? never saw numbers on one?
Fight the Good Fight- Elastomeric Bumpers and The Better "Shaker kits"
