Hub. honeing #1711096
12/15/14 06:26 PM
12/15/14 06:26 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
What are uall using to hone-out the crankshaft hub. on your ATI dampeners. So that they will have a better fit on the crankshafts....Thax.
Re: Hub. honeing [Re: racerx] #1711097
12/15/14 06:29 PM
12/15/14 06:29 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
My ATI didn`t need it on a stock crank but I had Pettis hone my Fluidampr...............
Re: Hub. honeing [Re: racerx] #1711098
12/15/14 06:31 PM
12/15/14 06:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I used a piece of 3/8 tubing with a slit in it and put
400 grit paper on it... rapped it around the tube till
it was fairly big then put it in a drill motor...
that was before I had a lathe
Re: Hub. honeing [Re: MR_P_BODY] #1711099
12/15/14 06:38 PM
12/15/14 06:38 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
That's what I was look for a diy way of doing it for some reason stone honing keep popping up in my mind..Lol :
Re: Hub. honeing [Re: racerx] #1711100
12/15/14 06:58 PM
12/15/14 06:58 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
I used a brake cylinder hone when I did my damper. also you can use a small ball hone. places like enco and kbctools etc sell them.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Hub. honeing [Re: Jerry] #1711101
12/15/14 07:08 PM
12/15/14 07:08 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I busted my brake cyl hone trying to do it.. kept
hanging up in the key way
Re: Hub. honeing [Re: racerx] #1711102
12/15/14 07:17 PM
12/15/14 07:17 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Brake hone is the best way. Make a wooden key to fit in the slot on the damper so u don't break the stones.
Re: Hub. honeing [Re: rickraw] #1711103
12/15/14 07:41 PM
12/15/14 07:41 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I didnt think of the wood spacer
Re: Hub. honeing [Re: MR_P_BODY] #1711104
12/15/14 07:44 PM
12/15/14 07:44 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Decide how big you want it.........take it to your local shop and have them do it on a rod machine. It will be done before you can jury rig something.......plus it will be straight
Monte
Re: Hub. honeing [Re: Monte_Smith] #1711105
12/15/14 07:54 PM
12/15/14 07:54 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Monte
Sunnen makes a keyway mandrel for that, I had to do mine. The book spec is .0005" to .0015" interference with .001" preferred. If you don't have equipment that reads in tenths, take your crank and balancer to the machine shop and have them hone it.
2011 Drag Pak Challenger
Re: Hub. honeing [Re: Monte_Smith] #1711106
12/15/14 09:32 PM
12/15/14 09:32 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Monte
Rod hone does it quick and easy.
Re: Hub. honeing [Re: JohnRR] #1711107
12/15/14 09:34 PM
12/15/14 09:34 PM
dogdays Offline
dogdays  Offline
Stuck mine in a 350 oven for a couple of hours, it went on with just a mild push plus a couple of taps.
R.
Re: Hub. honeing [Re: dogdays] #1711108
12/15/14 09:43 PM
12/15/14 09:43 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
R.
One could probably do that with a factory balancer on a factory crank , but aftermarket balancer , and a crank made by a diifferent company , I wouldn't bet on it .
Re: Hub. honeing [Re: JohnRR] #1711109
12/15/14 10:04 PM
12/15/14 10:04 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
R.
I have put them in water and boiled it for a few minutes to get enough
expansion to get it on. I mentioned that to Fluidamper and they said that was probably OK, they just had never thought of it.
If you like drag racing, support your local track.
Re: Hub. honeing [Re: CHAPPER] #1711110
12/15/14 10:32 PM
12/15/14 10:32 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
R.
What about getting it off though , heat or just sign of the cross and hope for the best ?
I have a magnetic bearing heater at work so I can get it up to 300-350 pretty effortlessly ...
Re: Hub. honeing [Re: CHAPPER] #1711111
12/15/14 10:37 PM
12/15/14 10:37 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
What you CAN do and what you SHOULD do are two totally different things. A certain amount of press is required. If you heat the thing hot enough, you can likely get it on even when the tolerance is way tight...........BUT, then you got to get it off at some point. If it is way tight, there are several scenarios. One you destroy a puller trying to get it off. Two, you drag metal out of the hub, or off the crank. One means you need a new hub. The other means you destroy the end of the crank. Sure, you can polish it off, but then you have drag marks and missing metal in hub or on crank snout. At that point the press is NEVER right, because you have incorrect surface area.
So.......WHAT TO DO?..........Check it..........fix it RIGHT
Monte
Re: Hub. honeing [Re: Monte_Smith] #1711112
12/15/14 10:50 PM
12/15/14 10:50 PM
Dyno1 Offline
Dyno1  Offline
I just installed my new ATI balancer. Measured the crank and the inside diameter of the hub, had it honed on a Sunnen rod machine. ATI says to use anti seize on the hub. If you get it to tight, good luck getting it off. Dyno
Re: Hub. honeing [Re: JohnRR] #1711113
12/15/14 11:56 PM
12/15/14 11:56 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
R.
Never had any problem getting them off using high pressure grease when installed. I'm not talking expanding it .005"+,,just maybe .001" or less with the 212* water heat. Just enough to go on easier with normal resistance than what it felt cold.
Re: Hub. honeing [Re: CHAPPER] #1711114
12/16/14 01:24 AM
12/16/14 01:24 AM
Cab_Burge Online work
Cab_Burge  Online Work
I heated the last SFI dampener up on my shop wood heating stove to 130F and it tapped on real nicely, I did use Permatex brand silver antiseize on the crank snout and in the dampener hub so it will come off eaiser than without it. I'm sure some of us who have worked on stock BB Chevy have thought we would break the dang puller before getting those dampeners off Most Mopars are a breeze to remove compared to them turds
Re: Hub. honeing [Re: Monte_Smith] #1711115
12/16/14 10:09 AM
12/16/14 10:09 AM
gregsdart Offline
gregsdart  Offline
Monte
And you can get press fit specs from the manufacturer and take the crank with to measure. Press fit is important for the damper to do its job.
