Howards made by a company you can't research or find called Steen in NW USA Killer for the $$ for reasonable spring pressures like street / mild bracket
Most others are Morel--good enough for everybody for years but...they also make upgraded versions with pressure fed oil, bigger wheels etc and the best are about $700 --they make for almost EVERYBODY
Crower/ Isky / Comp Elite and all the top end stuff is about the same ( Iskys run smallest on diameter--can be good or bad) Bushed are not much more--all are $700 range and the most dependable for higher spring pressures like over 650 open and well above
DO NOT restrict oil to roller lifters in any way and This is DOUBLE important for the bushed units
Consider rollers a once a year deal in serious race engines--get them out before they experience axle failure--
There have been some terrible issues with Johnson rollers and with the many imports--which when buying--Who really Knows??
Ask your engine builder--he should KNOW where his lifters come from--
Just plan on $700 for serious lifters and you can use a Comp 829-16 for lots less with no worry IF you check them at end of the season--The Compa has the advantage of being a solid body--something ALL mfg's should do with BB Mopar IMO but never will--so...we use lots of 829-16's in bracket engines and ...they will fit in many aftermarket blocks that would otherwise need Grinding/ milling for lifter room--they are the Go To for many builders.
I do have a set of Howards / Steens in one of my personal race cars--Light valves--550 open and they have been doing an excellent job for cheap!
