Dana 60 ID #1710331
12/14/14 12:13 PM
12/14/14 12:13 PM
S.W. Florida
blkbee6pack Offline OP
S.W. Florida
I have a Dana in a project car (not original to car) Where do I look for numbers and date codes to ID it?
Re: Dana 60 ID [Re: blkbee6pack] #1710332
12/14/14 12:21 PM
12/14/14 12:21 PM
Northern Pa
GLR Offline
GLR  Offline
Northern Pa
Right side (passenger side) of axle assembly on axle tube . If the axle is in car-look just to the right of the rear cover. You have to clean up the tube good-don't use a grinder..use a rust remover and wire brush or wire wheel in a drill.
Re: Dana 60 ID [Re: blkbee6pack] #1710333
12/14/14 12:22 PM
12/14/14 12:22 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
