Page 2 of 5 1 2 3 4 5
Re: lighten up a little ! NSS K frame goes under the kn [Re: BobsProFab] #171013
12/20/08 10:58 AM
12/20/08 10:58 AM
SE Nunya
Bubba Offline
Bubba  Offline
SE Nunya
always teasin' with the B-Body stuff.... I got a front end that needs a BondoBob Quick Weightloss Program...
Nice work Bob..... Have a great holiday!
Re: lighten up a little ! NSS K frame goes under the kn [Re: Bubba] #171014
12/20/08 11:07 AM
12/20/08 11:07 AM
SC
Greg Offline
Greg  Offline
SC
Doug,
I am pretty sure that he would need a core for the lightweight parts he is making, but Bob can elaborate on that. The K frame he is illustrating in the picture is an early version like the one in your car. It is a stock K Frame that is just being trimmed up and even strengthened with lighter chrome-moly. All attachment points stay the same as stock but just lightened. It appears that it is going to be somewhere around a 20+lb difference for the K Frame. Bob can make lightened CM steering shaft, strut rods and draglink for you guys that have to run stock pieces (class rules) or just like the stock look for appearance purposes.
When you start weighing all those parts the lightening makes a big difference. I am sure Bob will be able to give specifics but I would say 40-50 pounds from the front end while keeping the stock look for nostalgia series or maxwedge type racing.
Re: lighten up a little ! NSS K frame goes under the kn [Re: Bubba] #171015
12/20/08 11:12 AM
12/20/08 11:12 AM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
The main reason the stock K frames are so big and heavy is they have to carry the weight of the engine.
When you racers or even some street car guys go to a motor plate the K fram is only used to hold the steering box and idler arm and keep the front frame rails straight.
So if you plan on staying with a motor plate this is a great way to take some weight off the front and truly is a bolt on deal.
Re: lighten up a little ! NSS K frame goes under the kn [Re: 340RICK] #171016
12/20/08 11:33 AM
12/20/08 11:33 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
What's a motor plate...i gotta get me one of those
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: lighten up a little ! NSS K frame goes under the kn [Re: B3422W5] #171017
12/20/08 12:03 PM
12/20/08 12:03 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
I dont have/use a motor plate ... ??
would this not work for my application then ?
Re: lighten up a little ! NSS K frame goes under the knife [Re: BobsProFab] #171018
12/20/08 01:28 PM
12/20/08 01:28 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
its a shiney piece of aluminum that mounts to front of motor then attaches to the frame rails. supports the enigne instead of stock motor mounts.
Re: lighten up a little ! NSS K frame goes under the knife [Re: 340RICK] #171019
12/20/08 04:09 PM
12/20/08 04:09 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
So thats what they are, cool
...learn something every day
1.41 best 60 foot
6.56 at 104.17
Re: lighten up a little ! NSS K frame goes under the knife [Re: B3422W5] #171020
12/20/08 04:11 PM
12/20/08 04:11 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Your A fuuny man don !
Re: lighten up a little ! NSS K frame goes under the knife [Re: VernMotor] #171021
12/20/08 05:21 PM
12/20/08 05:21 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I am pumped, my Spartans just knocked off Texas down in Texas
I think i need a motorplate to stabilize my head, it needs to be about 3/4 inch thick billet
1.41 best 60 foot
6.56 at 104.17
Re: lighten up a little ! NSS K frame goes under the knife [Re: VernMotor] #171022
12/20/08 05:22 PM
12/20/08 05:22 PM
sycamore,ohio
BobsProFab Offline OP
sycamore,ohio
OK heres the finished k frame.
it weighed in at 21 lbs. finished not bad for start out in the 40 lb. range
i sectioned it togther with 1 5/8 moly and struted it with 1" moly
it still retains the same shape far as the drop in the k frame but has 2 more inches of clearance on the sides.
here you go Greg
Re: lighten up a little ! NSS K frame goes under the knife [Re: BobsProFab] #171023
12/20/08 05:24 PM
12/20/08 05:24 PM
sycamore,ohio
sycamore,ohio
Re: lighten up a little ! NSS K frame goes under the knife [Re: BobsProFab] #171024
12/20/08 05:24 PM
12/20/08 05:24 PM
sycamore,ohio
sycamore,ohio
Re: lighten up a little ! NSS K frame goes under the knife [Re: BobsProFab] #171025
12/20/08 05:25 PM
12/20/08 05:25 PM
sycamore,ohio
sycamore,ohio
Re: lighten up a little ! NSS K frame goes under the knife [Re: BobsProFab] #171026
12/20/08 05:26 PM
12/20/08 05:26 PM
sycamore,ohio
sycamore,ohio
Re: lighten up a little ! NSS K frame goes under the knife [Re: BobsProFab] #171027
12/20/08 05:27 PM
12/20/08 05:27 PM
sycamore,ohio
sycamore,ohio
Bondo
Re: lighten up a little ! NSS K frame goes under the knife [Re: BobsProFab] #171028
12/20/08 05:52 PM
12/20/08 05:52 PM
SC
Greg Offline
Greg  Offline
SC
Bob,
Man you work fast. I shipped the K frame to Bob and a week later look at what he has done. Great customer service and workmanship. I definately would not hesitate to use Bob's services again.
Re: lighten up a little ! NSS K frame goes under the knife [Re: BobsProFab] #171029
12/20/08 05:57 PM
12/20/08 05:57 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Looks very nice Bob..gezz Now I got to work on my !
Re: lighten up a little ! NSS K frame goes under the knife [Re: VernMotor] #171030
12/20/08 06:14 PM
12/20/08 06:14 PM
Q
Quicktree Offline
Quicktree  Offline
Q
nice work Bob the K frame in my challenger has some weight taken out. don't know if you can see it in this pic.
Re: lighten up a little ! NSS K frame goes under the knife [Re: BobsProFab] #171031
12/20/08 06:29 PM
12/20/08 06:29 PM
detroit area
moderncylinder Offline
detroit area
you going to put a ring on the front to hook up a tow strap? might be a good idea once its there,,,,
Re: lighten up a little ! NSS K frame goes under the knife [Re: moderncylinder] #171032
12/20/08 06:32 PM
12/20/08 06:32 PM
sycamore,ohio
sycamore,ohio
yes it gets a tow ring, im out of moly that size
should be here monday
