Page 1 of 3 1 2 3
TTI's for Borgeson Box #1709927
12/12/14 06:43 PM
12/12/14 06:43 PM
USA
Consulier Offline OP
USA
I broke down and got a set of the updated TTI's to clear a Borgeson Box. Figured my 2" hit pretty much everything, so maybe the updated design would help.
This is how they look straight out of the box...
So, instead of being dented after you get them, they just do it for you now?
Is this really what they call a fix? Seems a little strange that this is the solution.
Re: TTI's for Borgeson Box [Re: Consulier] #1709928
12/12/14 06:57 PM
12/12/14 06:57 PM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
Lol
Did the 2" not have the denting to clear the TB's? They have to be there to clear the TB's on my car.
That's exactly how my second set came. The first set didn't have the middle dent- I had to add it.
Anyway, I don't see those dents as a restriction- or at least not one that matters.
Have you had a chance to test fit them yet?
-'02 Dodge Viper Ex-World Challenge racecar
-'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
Re: TTI's for Borgeson Box [Re: Uhcoog1] #1709929
12/12/14 07:12 PM
12/12/14 07:12 PM
USA
USA
2" came without "customizing"...
I should have put my R5 in with custom headers and been done with it.
If I was test fitting them, I probably would not be so bitter about all this. But, when you are paying somebody else to find out that the stuff the experts made is crap... it gets old real fast. I'll have more details next week on fitment.
Luckily mounts were made to their exact K member placement specs. So, if they don't fit, I swear I'm getting on a plane to CA.
Re: TTI's for Borgeson Box [Re: Consulier] #1709930
12/12/14 08:07 PM
12/12/14 08:07 PM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
send it back.... it got damaged in shipping!
Wow that's pretty bad! I'd be pissed! I'd expect more from TTI..... just sayin! We pay what? 3x what a Chevy owner would pay for parts and get that crap?
Re: TTI's for Borgeson Box [Re: Consulier] #1709931
12/12/14 09:24 PM
12/12/14 09:24 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Yeah that's why I'm going to use Schumacher mounts instead of TTI mounts
Seeing that crap, I am half tempted to send my car to Doug Thorley's in SoCal to get a set of headers fabbed up for Gen 3 swaps
or get a custom set made, whatever is cheaper
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: TTI's for Borgeson Box [Re: RylisPro] #1709932
12/12/14 09:45 PM
12/12/14 09:45 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
My tti's had to be clearanced for the 1.22" bars.
If you don't have to take a hammer to it, it's not hot rodding.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: TTI's for Borgeson Box [Re: AlexP] #1709933
12/12/14 10:24 PM
12/12/14 10:24 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Seriously, is the way those headers are routed the most clear path? As in there is absolutely no clearance for the tubes to go up, down, left, right and necessitate being dented?
I find it hard to believe even in an A body?
I'm sure it would not be as bad in B/E bodies, but damn
for the money you would expect they would get it right.
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: TTI's for Borgeson Box [Re: AlexP] #1709934
12/12/14 10:26 PM
12/12/14 10:26 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
For the amount of money those tti-tubes always seem to cost they could at least provide a personal inscripted 2 lbs hammer to go with the header purchase...
Re: TTI's for Borgeson Box [Re: BigBlockMopar] #1709935
12/12/14 11:37 PM
12/12/14 11:37 PM
Santa Fe Springs, CA
Dan@Hotchkis Offline
I was under a car yesterday and saw a much better way to route the pipes(TTI's on it now), and then I realized something... I think they design their tubes to work with the factory Z bar on most applications. It leaves a lot of unused real estate on the hydraulic clutch / auto cars. I wonder how much better the stuff would fit if they just made it to fit auto/hydraulic clutch cars?
Re: TTI's for Borgeson Box [Re: Dan@Hotchkis] #1709936
12/13/14 03:48 PM
12/13/14 03:48 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
They have room for the Magnum starter too. I'm gonna use an 05 ram 2500 5.7/5spd starter which also makes a bunch more room.
Mopar to the bone!!!
Re: TTI's for Borgeson Box [Re: 72Swinger] #1709937
12/13/14 10:57 PM
12/13/14 10:57 PM
GA
roadrunninMark Offline
GA
72Swing..do you have some pics of the two starters side by side? Would like to see the size difference.
Re: TTI's for Borgeson Box [Re: roadrunninMark] #1709938
12/14/14 12:20 AM
12/14/14 12:20 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
As a matter of fact I do....
I don't take credit for this little gem, I learned it on FABO, but I think Wade Uchoog is using one. I have to relocate my factory proportioning valve location to clear the #3 or #5 tube too FYI.
Re: TTI's for Borgeson Box [Re: 72Swinger] #1709939
12/14/14 12:48 AM
12/14/14 12:48 AM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
Good starter. Fits better than the adjustable one TTI used to recommend. Slides in and out easily.
http://m.summitracing.com/parts/dcc-56029274aa
I can't take credit for the find- I learned of it on FABO as well.
Re: TTI's for Borgeson Box [Re: 72Swinger] #1709940
12/14/14 12:49 AM
12/14/14 12:49 AM
Plano, Texas
68cuda440 Offline
68cuda440  Offline
Plano, Texas
Does this little gem fit a 440? And will it spin one with 11.25:1 CR?
-Michael
Michael 1968 Barracuda Notchback Coupe 440 EFI 6-pack, T56 Magnum 6-spd
Re: TTI's for Borgeson Box [Re: Dan@Hotchkis] #1709941
12/14/14 01:02 AM
12/14/14 01:02 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
re: TTI routing
At least on the a-bodies, TTI has a modified Z bar (or you have the option of doing it yourself).
re: custom headers
Performance welding if your on the west coast is worth a look and maybe a call. The website is Perfweld IIRC. Mark is no stranger to mopars as you can see on his website. Might even be have some experience with those big primaries. Stainless so less heat transfer and less rust. Price range is what you'ld expect for custom stainless.
Re: TTI's for Borgeson Box [Re: 68cuda440] #1709942
12/14/14 01:09 AM
12/14/14 01:09 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
-Michael
Well the Mopar mini starter it is replacing was on my BB if that tells you anything lol.
Re: TTI's for Borgeson Box [Re: 72Swinger] #1709943
12/14/14 01:17 AM
12/14/14 01:17 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Can you mount that on the driver side and use a 10.5" 130 tooth flywheel?
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: TTI's for Borgeson Box [Re: RylisPro] #1709944
12/14/14 01:27 AM
12/14/14 01:27 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Trucks are driver side, and yes that is what I and Wade are using for flywheel.
Re: TTI's for Borgeson Box [Re: 72Swinger] #1709945
12/14/14 12:45 PM
12/14/14 12:45 PM
GA
GA
That is quite a big difference in size! Now does a starter care about how many teeth are on a flywheel? I have a 143 tooth flywheel for the RR for my 440.
Re: TTI's for Borgeson Box [Re: roadrunninMark] #1709946
12/14/14 01:04 PM
12/14/14 01:04 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
TTI says to use that starter with a 143t flywheel
that's why I asked my question
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Page 1 of 3 1 2 3
