Gas tank pads DTM?
#1709706
12/11/14 10:58 PM
12/11/14 10:58 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Well I am trying to get the gas tank into my Charger so I have been acquiring the parts to complete that install. I went and ordered a replacement filler neck, new tank, etc. Well I went to get a replacement pad for the tank to trunk floor, what a headache. There are 3 major types of pads, foam rubber, 30lb roofing felt and one supplier of originals. So from what I can tell, the foam ones retain water. The 30lb roofing felt has changed since the 80's, I measure some today and it was only .017" thick where the orignal pad on my car measured .063. The original replacement pad was $159.99 from Jim's Auto Part. Well after further searching, I found that DMT carries one that is almost the same thickness as the original from their ad. So I ordered one from them on the bay, hopefully everything is not like this when ordering parts...I will post on the quality when I get it. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
Re: Gas tank pads DTM?
[Re: OzHemi]
#1709708
12/11/14 11:25 PM
12/11/14 11:25 PM
astjp2
Utah and Alaska
Ok, I never thought to look them up to see if they were reputable sellers or not. Seem that most on here are. Tim
[Re: astjp2]
#1709710
12/12/14 07:46 PM
12/12/14 07:46 PM
Posts: 74,979 U.S.S.A.
JohnRR
U.S.S.A.
Jim's auto parts is not on here .
