Re: 69 Satellite to Charger question
[Re: Mr.Yuck]
#1709410
12/11/14 02:31 PM
12/11/14 02:31 PM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
I think the wheel base on a Plymouth is 1-2" shorter than a Charger. I could be wrong. I guess if he has mad skills it could be done. He'd be better off selling the Charger parts and what's left of the Satellite and buying a complete Charger project.
The wheelbase on the charger is a little longer than the Satellite , but a lot of it is in the spring hanger attached to the front of the leaf springs.
The person could buy rear frame rails and all the sheet metal, including the roof and trunk floor, and make the satellite a charger , it would be a lot of work , it would be easier to find a charger wit ha wrecked nose and put the 2 halves together ...
Or just buy a charger ...
[Re: carmak]
#1709412
12/11/14 02:49 PM
12/11/14 02:49 PM
JohnRR
U.S.S.A.
Finding a solid Charger to build has been a challenge here smack dab in the middle of the rust belt.
I wonder if the Charger convertibles out there have shortened qtrs. or stretched floors/frame rails?
Carmak
We have a member here that made one , Chargervert , I imagine he put the charger trunk floor in ?
[Re: JohnRR]
#1709413
12/11/14 06:32 PM
12/11/14 06:32 PM
Posts: 15,995 RI Deep in the rust belt
chargervert
All I had to do was change the front spring hangers to Charger pieces. I used a Charger trunk floor pan. Frame rails are the same. To convert the Satellite to a Charger hardtop,would require changing the rear window inner structure to Charger pieces. The trunk floor wiil need to be changed or modified for the filler tube. The outer wheel houses will also need to be changed to Charger pieces,as well as the trunk extensions. The tail panel,rear valance,and corners would also have to be fitted to the AMD Charger quarter panels. An AMD roof skin and dutch panel would also be needed. It is doable.
70 Charger R/T SE 472 Hemi
70 Charger R/T convertible
70 Charger R/T V Code Sixpack
69 Charger R/T SE Sunroofcar
68 Charger 383
68 Charger 318
71 Charger R/T
70 Challenger convertible
71 Challenger convertible
71 Cuda 340
09 Challenger R/T Classic
[Re: chargervert]
#1709414
12/11/14 07:46 PM
12/11/14 07:46 PM
JohnRR
U.S.S.A.
How is the angle of the rear spring shackles with the spring moved rearward ?
[Re: JohnRR]
#1709415
12/11/14 07:56 PM
12/11/14 07:56 PM
chargervert
The shakles on the Dodge is raked back and the shakles on the Plymouths are more vertical. I believe the rails are the same. The difference is just under an inch. I have never seen replacement rear rails listed as different parts from Dodge to Plymouth.
68 Charger 383
68 Charger 318
71 Charger R/T
71 Cuda 340
[Re: DaytonaTurbo]
#1709417
12/11/14 11:29 PM
12/11/14 11:29 PM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
Back half it, tub it and hang the sheet metal. On the frame rail conversion: So the rear frame rails from a Cornet, Satelite and Charger are all the same on 68-69 cars?
Careful, your character's showing!
[Re: mopar346]
#1709418
12/11/14 11:47 PM
12/11/14 11:47 PM
chargervert
I believe the frame rails are the same. The front leaf spring brackets are 1 inch longer on the Dodge than they are on the Plymouth.
68 Charger 383
68 Charger 318
71 Charger R/T
71 Cuda 340
[Re: chargervert]
#1709420
12/12/14 12:01 AM
12/12/14 12:01 AM
Posts: 12,494 Western Colorado High Desert
moparmarks
Yes the frames are the same and the front spring hanger is a inch longer on the Dodges. Also the box where the rear shackles hang has the hole an inch back on the Dodges. Thus the inch longer wheel base.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: moparmarks]
#1709421
12/12/14 12:05 AM
12/12/14 12:05 AM
mopar346
So they are the exact same on a Coronet and a Charger?
[Re: chargervert]
#1709422
12/12/14 12:08 AM
12/12/14 12:08 AM
moparmarks
Pretty much covers the back half. Then need doors, hood, fenders, front valance, grill with mounts, head light assy., bumpers with mounts, Rallye dash, interior panels, etc. etc. A lot to piece together if you don't have a good parts car and still would have a Satellite vin number...
[Re: moparmarks]
#1709424
12/12/14 12:14 AM
12/12/14 12:14 AM
mopar346
Hmmm.............
Thank you.
[Re: mopar346]
#1709425
12/12/14 11:59 AM
12/12/14 11:59 AM
JohnRR
U.S.S.A.
Coronet , charger yes , satellite NO .
thanks Mark , I figured threre was a difference back there. I have both a plymouth and dodge front hanger bracket , never made a measurement to see how big the difference was.
[Re: JohnRR]
#1709426
12/12/14 08:35 PM
12/12/14 08:35 PM
Posts: 2,415 Connecticut
Ron_M
Connecticut
I could be wrong, but I thought the jambs are wider on the Charger(?)
Common sense is a flower that does not grow in everybody's garden
[Re: Ron_M]
#1709427
12/12/14 09:18 PM
12/12/14 09:18 PM
moparmarks
Latch jam? Could be. Books show different part number for Charger than H/T B.
