Page 2 of 3 1 2 3
Re: My little project car, not a mopar but close [Re: gremlinsteve] #1709302
12/17/14 01:07 AM
12/17/14 01:07 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
I like the look of the Level 8 Wheels strike 5s. I am probably going to get a set of 17 X 9 for my Barracuda-$$ a little tight right now.
Re: My little project car, not a mopar but close [Re: Skeptic] #1709303
12/18/14 07:11 AM
12/18/14 07:11 AM
houston texas
gremlinsteve Offline OP
houston texas
Decided to order up a msd atomic efi for the car.
Got it so cheap I could not pass it up.
Also picked up wildwood front and rear braking systems for the car
if You Like Gremlinsteve. Gremlinsteve Likes You.
Re: My little project car, not a mopar but close [Re: gremlinsteve] #1709304
12/18/14 06:20 PM
12/18/14 06:20 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Have an Atomic on our 55 T Bird 292 with a 4 speed AOD Mustang automatic transmission.
Have struggled for a year now with its predilection for the engine to stall when coming to a stop. Have gone thru several firmware upgrades to ECU. Is slowly becoming more reliable but has been a pita. Have high hopes for it once it settles down.
Can you share what was too good a price to pass?
Re: My little project car, not a mopar but close [Re: Sxrxrnr] #1709305
12/19/14 01:28 AM
12/19/14 01:28 AM
houston texas
houston texas
Why'll, I have a total of 3k in all of the parts. Willwood brakes front and rear and the msd efi
Normal would have been 3600-3700
Re: My little project car, not a mopar but close [Re: Sxrxrnr] #1709306
12/19/14 01:46 AM
12/19/14 01:46 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Does the Atomic use an Idle Air Control and can you read data logs from the system. The data log can tell you if it is going rich or lean before it quits. Ideally it should idle 90% on the throttle blade setting and use the IAC (if it has one) to trim it on the fly.
This is assuming that it has a wide band O2 controller to run it closed loop.
Sorry for the hijack
Kevin
Re: My little project car, not a mopar but close [Re: Twostick] #1709307
12/19/14 05:04 AM
12/19/14 05:04 AM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Atomic has Idle Air Control(IAC)adjustment via throttle blades. Page 14 of installation manual.
http://static.summitracing.com/global/images/instructions/msd-2900.pdf
Unfortunately no data logging facility which is a weakness in the system which confounds troubleshooting efforts.
System does utilize a single O2 sensor.
Re: My little project car, not a mopar but close [Re: Sxrxrnr] #1709308
12/21/14 10:21 PM
12/21/14 10:21 PM
houston texas
houston texas
Photoshop done sye one or e
Re: My little project car, not a mopar but close [Re: gremlinsteve] #1709309
12/27/14 12:28 AM
12/27/14 12:28 AM
houston texas
houston texas
New up
Dates are, the Willwood brakes are on these way
Also ordered a atomic efi that also shipped and a new hood. He hod is a fiberglass piece that has a 70 amx scoop
The gas tank is being restored since it's full of crud
I am about to pull the front suspension apart and install the poly bushings also.
Soils should be ready for a good cleaning of its underside and then off o paint
Re: My little project car, not a mopar but close [Re: gremlinsteve] #1709310
01/19/15 10:47 PM
01/19/15 10:47 PM
houston texas
houston texas
Gas tank was fixed by bead blasting the interior and a coating system called renew used.
The efi is on the car and working.
Sounds any runs good, but I have not driven it yet.
I pre assembled the brand system last week. Waitin fora better time to instal as the weather in fixin to go south again.
I'll try to snap some pics
Re: My little project car, not a mopar but close [Re: gremlinsteve] #1709311
01/20/15 03:15 PM
01/20/15 03:15 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I was gonna ask why you didn't just get a new tank, my experiences with fuel tank liners, while 30 years ago and on motorcycles, is bad so I am leery. But then I see finding a new tank for your Gremlin is hard to do so never mind and good luck.
Don't be the exception.
Re: My little project car, not a mopar but close [Re: gremlinsteve] #1709312
01/21/15 01:42 PM
01/21/15 01:42 PM
houston texas
houston texas
They do not make tanks for gremlins
I had no choice. Plus it's a lifetime warranty do I'll have to trust it
Here is a pic or two of the brakes
Re: My little project car, not a mopar but close [Re: gremlinsteve] #1709313
01/21/15 01:43 PM
01/21/15 01:43 PM
houston texas
houston texas
One more
Re: My little project car, not a mopar but close [Re: gremlinsteve] #1709314
01/21/15 04:23 PM
01/21/15 04:23 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I had no choice.
I found that out trying to help, lol.
All else fails, if you need to I guess Tanks, Inc can use your old one as a pattern to make you a new EFI one, but that is the expensive route. Might be able to talk them into a slight discount as you would be providing them a new line item to sell, must be one or two other Gremlin fans out there
My old lady would love one, but I have seen exactly one in this town in the last decade and it wasn't for sale. I have vivid memories of helping push my Pop Warner football coach's Gremlin back when I was a kid. It was bright Green, lol.
Re: My little project car, not a mopar but close [Re: Supercuda] #1709315
01/21/15 05:42 PM
01/21/15 05:42 PM
Sorrento, BC, Canada
4speeds4me Offline
4speeds4me  Offline
Guy in highschool had one with a 401/4-speed. Parked it when the left front wheel would no longer touch the ground.
2 Demons...no, not my kids!
Re: My little project car, not a mopar but close [Re: Supercuda] #1709316
01/21/15 10:28 PM
01/21/15 10:28 PM
houston texas
houston texas
What's funny is they make a brake system and even some 1 and a eighth sway bars
But not that stuff that makes it actually remain running.
This gas tank liner has a lifetime warranty. So I hope it was worth the funds. Other wise I am going to be building a fuel tank.
I had no choice.
Re: My little project car, not a mopar but close [Re: gremlinsteve] #1709317
01/23/15 09:50 AM
01/23/15 09:50 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
I love those Gremlins,when I got out of the service in 73 I bought a LEVI GREMLIN.it was white w/ all LEVI int.Now I wish I would have kept it.
Re: My little project car, not a mopar but close [Re: bonefish] #1709318
01/23/15 10:43 PM
01/23/15 10:43 PM
houston texas
houston texas
Thanks for the likes. And as soon as the weather breakers I'm without pneumonia and time is right , I'll pop in the sway bars, the front and rear brakes and tidy up wring.
Then it's time for wheels and tires along with the repaint.
Re: My little project car, not a mopar but close [Re: gremlinsteve] #1709319
01/24/15 11:53 PM
01/24/15 11:53 PM
houston texas
houston texas
Rear will woods pre fabbed
As usual it's a simple setup
Re: My little project car, not a mopar but close [Re: gremlinsteve] #1709320
01/24/15 11:54 PM
01/24/15 11:54 PM
houston texas
houston texas
Rears
Re: My little project car, not a mopar but close [Re: gremlinsteve] #1709321
01/24/15 11:55 PM
01/24/15 11:55 PM
houston texas
houston texas
Caliper
Page 2 of 3 1 2 3
