Page 1 of 5 1 2 3 4 5
Another SB Stroker question? What year 360 block?? #1709005
12/10/14 04:45 PM
12/10/14 04:45 PM
Wisconsin
wkroncke17 Offline OP
Wisconsin
All,
Looking to build a 408 stroker - 500 HP at the most.
I've read tons on all of the builds/cranks/kits etc.
is there any year 360 engine that is more desire able than others? Or are they all just the same?
I prefer LA, not magnum.
BUT......is there any advantage to Magnum over LA, or vice versa?
Thanks all!
Re: Another SB Stroker question? What year 360 block?? [Re: wkroncke17] #1709006
12/10/14 06:12 PM
12/10/14 06:12 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
For 500 hp any block should be fine as long as it sonic tests fine, most are still fine at that level even without testing if you don't go crazy on bore size.
The strongest production 360 block out there is a magnum block. Unless you are bent on running LA heads, in that case you got to get oil to the shaft somehow, either add an oil line, PR oil them and hope for the best, find a machine shop that can drill the hole through the deck and hit the cam bearing hole, or use a 89-92 block so you can still use the roller cam at least. If a big bore is the primary concern and you want to run flat tappet (or pay for conversion) then a 70-71 block is supposed to have thick bores but 40+ years of neglect tends to rot the cylinders from the water jacket side of things so again you need to sonic test.
Long story short run a magnum block with magnum based heads so you get the strongest, least corroded, roller set up, EFI ready for the future (or now).
Re: Another SB Stroker question? What year 360 block?? [Re: wkroncke17] #1709007
12/10/14 06:14 PM
12/10/14 06:14 PM
Peoria, AZ
P
PIPES Offline
PIPES  Offline
P
Peoria, AZ
I built mine from a 75ish smogger LA motor about ten years ago, it runs high 11's in my Aspen and is still going strong. That being said, I kinda wish I would have used a magnum. Roller cams are worth a bit of extra power and you don't have to worry about proper break in or what oil to use later. I know I can run a roller in my LA block with some work or retro-fit lifters but I built it like 10 years ago and if I was to do that swap now I may as well plan a whole new build.
Just my there are others here that know better than me I am sure.
80 Aspen R/T
Eddy headed 408
New Best 11.83 @ 112
Gettin' quicker
Re: Another SB Stroker question? What year 360 block?? [Re: wkroncke17] #1709008
12/10/14 06:31 PM
12/10/14 06:31 PM
Az
Crizila Offline
Crizila  Offline
Az
All,
Thanks all!
No proof on this, but the E58 coded motors were supposed to have hand picked parts off the assembly line with tighter tolerance's. Again, hear-say on the block, but for sure they came with things like HD water pump bearings, special silicone valve cover gaskets, nimonic exhaust valves, double roller timing chain / sprockets, windage tray, HD bearings, HD manifold castings, extra clearance for valve stems / ring lands, specially selected cast iron crank ( no under cuts form the factory ). Fifth didget on the vin will be an "L" to designate E58 motor. The 2 that I have had sonic tested have had walls in the .2 range. On the other side, ran a 71 block out of a motor home for a few years ( in the 500 HP range ) with no problems.
Fastest 300
Re: Another SB Stroker question? What year 360 block?? [Re: Crizila] #1709009
12/10/14 06:54 PM
12/10/14 06:54 PM
Tucson, Arizona
clonestocker Offline
Tucson, Arizona
I've got a 1975 E58 Block stashed in the shop. I think I need to have it sonic checked.
[img] [/img]
Re: Another SB Stroker question? What year 360 block?? [Re: HotRodDave] #1709010
12/10/14 09:22 PM
12/10/14 09:22 PM
Wisconsin
Wisconsin
Whoa! Now there's some info I never knew!
I was thinking about running a hydraulic roller cam....so, it sounds much simpler oiling wise to use a magnum block/heads?
And if the magnum block is stronger in general, I may want to use one regardless?
This I a all very useful information, and I appreciate it very much!
So for another (maybe dumb) question, what year dod the 360 become a magnum?
Thanks again!
Wally
Re: Another SB Stroker question? What year 360 block?? [Re: wkroncke17] #1709011
12/10/14 09:55 PM
12/10/14 09:55 PM
jacksonville,FLORIDA
slammedR/T Offline
slammedR/T  Offline
Thanks again!
Wally
92 for 318 and 93 for 360 but I have a 92 360 block that have magnum provisions. Also the magnum block still had LA oilling up to 95. My current block is a 95 date code magnum 360 block and it still has the LA oil feed provision. I agree with the magnum blocks, was always told they were weak, but have never seen one break yet, but I'm darn sure trying
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: Another SB Stroker question? What year 360 block?? [Re: wkroncke17] #1709012
12/10/14 10:02 PM
12/10/14 10:02 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
93-03
Re: Another SB Stroker question? What year 360 block?? [Re: HotRodDave] #1709013
12/10/14 10:27 PM
12/10/14 10:27 PM
Post falls, Idaho
rgreule Offline
rgreule  Offline
Post falls, Idaho
ive always been told that the 496 castings are the best to have for a 360 block
Re: Another SB Stroker question? What year 360 block?? [Re: rgreule] #1709014
12/10/14 10:54 PM
12/10/14 10:54 PM
Wisconsin
Wisconsin
And the 496 castings are what years?
Good stuff guys, I greatly appreciate it!
Re: Another SB Stroker question? What year 360 block?? [Re: wkroncke17] #1709015
12/10/14 11:38 PM
12/10/14 11:38 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
This one is a 71 block, one of the nicest cast webs and bored I've seen out of many 340-360 castings.
Made a 440 W2 mild (251/259 Bullet) solid roller torque monster out of it
WIZE
In Car:
Re: Another SB Stroker question? What year 360 block?? [Re: wkroncke17] #1709016
12/10/14 11:45 PM
12/10/14 11:45 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
71 to 73/74 I thought were the thick wall 360 blocks with the 340 cyl just not bored out to 4.04. Anyway I run a 73 360 without any problems. Never had it sonic tested.
Re: Another SB Stroker question? What year 360 block?? [Re: ademon] #1709017
12/11/14 01:34 AM
12/11/14 01:34 AM
Glendale Az
Darryls-Demon Offline
Glendale Az
I had a 71 360 standard bore block that was so thin it was not safe to go .030 over.
I ended up using a 78 block that was very thick.
You need to sonic check any OEM block.
Re: Another SB Stroker question? What year 360 block?? [Re: Darryls-Demon] #1709018
12/11/14 01:50 AM
12/11/14 01:50 AM
slammedR/T Offline
slammedR/T  Offline
racemagnum
Re: Another SB Stroker question? What year 360 block?? [Re: slammedR/T] #1709019
12/11/14 01:55 AM
12/11/14 01:55 AM
pacific northwest
Stroker Scamp Offline
pacific northwest
Mine is a 78 out of a cop car, sonic checked OK but had some thin spots, its got a partial fill and it sits more than its raced at this point
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Another SB Stroker question? What year 360 block?? [Re: Stroker Scamp] #1709020
12/11/14 03:06 PM
12/11/14 03:06 PM
Wisconsin
Wisconsin
Well, after one phone call, and a couple text messages, I've secured myself a 360 '73 model year that was in a camper with only 50k miles for $100!
I think that's what il be going with!!
Re: Another SB Stroker question? What year 360 block?? [Re: wkroncke17] #1709021
12/11/14 03:09 PM
12/11/14 03:09 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
You will kick yourself for not running a Magnum motor.
Re: Another SB Stroker question? What year 360 block?? [Re: TheOtherDodge] #1709022
12/11/14 03:29 PM
12/11/14 03:29 PM
Wisconsin
Wisconsin
Well, for $100 I'm not losing out, and nothing is final until the the block gets sent to machine shop.
Could you please explain the advantages of running a magnum motor?
I'm ignorant to any of this info as the last engine I built was about 30 years ago, and it was a 360 about like this one.
There's still time for me to get a magnum motor if I really feel the need to.
Thank you!
Re: Another SB Stroker question? What year 360 block?? [Re: wkroncke17] #1709023
12/11/14 03:40 PM
12/11/14 03:40 PM
Houston, Texas
Houston, Texas
I think several people have already explained the advantages.
Here is a recap:
Roller cam ready - can use stock hydraulic roller lifters
Rocker arms - can use Chevy style (in expensive)
Blocks - plenty of them around and stronger than LA block
Much easier to convert to FI if desired.
Re: Another SB Stroker question? What year 360 block?? [Re: wkroncke17] #1709024
12/11/14 03:45 PM
12/11/14 03:45 PM
ccarson Offline
ccarson  Offline
71 360 Block here, the thinnest thrust side dim is .210" only bored .030" could have went bigger but round and straight is better than a couple of extra CU IN.
