Re: Engine swaps for 72-80 trucks- max mileage [Re: blown340] #1708918
12/13/14 10:50 PM
12/13/14 10:50 PM
Cruising!
Q
QuickDodge Offline
QuickDodge  Offline
Q
Cruising!
A two wheel drive will almost always use less fuel than a 4x4.
There are many small diesel engines which can be used. I'd suggest a small turbo diesel for best mileage & power. The 4bt has a great reputation, but these are popular engines and often a bit expensive to purchase. Most of the small cab over trucks have suitable diesel engines.
The OP did not state why mileage is important. If low operating cost is the motivation, they may want to consider switching a gasoline engine over to run on compressed natural gas if it is available in their area.
Re: Engine swaps for 72-80 trucks- max mileage [Re: DaytonaTurbo] #1708919
12/14/14 12:43 AM
12/14/14 12:43 AM
IN
ahy Offline
ahy  Offline
IN
A 318 magnum swap is probably the best bang for your buck. Reasonably low mileage 318 magnums can be found. But whether or not you keep the fuel injection, one thing you can really do to get the efficiency up is to take the engine apart and have the block decked to get the pistons up to zero deck, then run a .040 head gasket. Stock the pistons are just a little too far down in the hole and the head gaskets I think are a little too thick. Doing this will get the compression up a bit and set it up for quench. IMO worth it for the real wold efficiency and power gains.
Sounds like a good approach to me...
Re: Engine swaps for 72-80 trucks- max mileage [Re: ahy] #1708920
12/14/14 05:03 PM
12/14/14 05:03 PM
Cruising!
Q
QuickDodge Offline
QuickDodge  Offline
Q
Cruising!
If I recall correctly, back in the 1980's the 2 wheel drive, 1/2 ton, 318 powered trucks with the 833OD (4 speed overdrive) transmission and 2.94 gears would often get 18 to 20 mpg on the highway. If this is correct, this set-up would be a bolt in deal and very easy to hook everything up. It would probably be rather affordable also.
The newer 318 magnums with a 5 speed or 518 automatic would probably have similar fuel mileage, but would have more power. It is a bit more work to hook up the fuel injection though.
One other point to consider is how long will the investment in the drive train conversion would take to break even. For example, I would guess a Cummins 4bt conversion could easily cost several thousand dollars. Such a swap would save fuel, but with the higher cost of diesel fuel and the high cost of the conversion, I suspect it would take MANY, MANY miles to before that owner is actually saving any money.
I love my old truck and wanted to drive it everyday, but after calculating the costs, I decided to get a car for everyday use. Other people will be in different situations. For some, an economical truck is the best option. In my case, it was a want rather than a need, so I drive a car now. It is not all bad though because I typically save about $200 per month in fuel!
Re: Engine swaps for 72-80 trucks- max mileage [Re: QuickDodge] #1708921
12/15/14 01:53 AM
12/15/14 01:53 AM
South Coast of Oregon
dweller Offline
dweller  Offline
Don't forget that the 4BT does not have a balance shaft and does vibrate a lot. It will shake the whole truck.
Re: Engine swaps for 72-80 trucks- max mileage [Re: dweller] #1708922
12/15/14 02:54 AM
12/15/14 02:54 AM
Canada
demon Offline OP
demon  Offline OP
Canada
What about the 4.7 v8? They seem to be overlooked. I have heard that the 5.2 Dakotas had better power and mileage than he 4.7's though.
If I could find a good, cheap 92-93 Ramcharger, I would just swap a 74-80 body on and that would be the simplest
Re: Engine swaps for 72-80 trucks- max mileage [Re: demon] #1708923
12/15/14 06:35 AM
12/15/14 06:35 AM
Pyeongtaek, South Korea
69HemiGTX Offline
69HemiGTX  Offline
That's easier said than done. The RC has a 106" wheelbase, whereas a regular cab shortbed truck is 115." Their frames are different. You'd be better off swapping the drivetrain.
OIF V and OEF X veteran and proud of it!
Re: Engine swaps for 72-80 trucks- max mileage [Re: 69HemiGTX] #1708924
12/15/14 05:44 PM
12/15/14 05:44 PM
Canada
demon Offline OP
demon  Offline OP
Canada
My plan is to swap an older Ramcharger body onto a newer Ramcharger frame to gain fuel injection, part time, overdrive etc
Re: Engine swaps for 72-80 trucks- max mileage [Re: demon] #1708925
12/15/14 09:04 PM
12/15/14 09:04 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
What's wrong with the newer ramcharger body?
Re: Engine swaps for 72-80 trucks- max mileage [Re: DaytonaTurbo] #1708926
12/15/14 11:08 PM
12/15/14 11:08 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
What's the wheel base on the Durangos?
Re: Engine swaps for 72-80 trucks- max mileage [Re: demon] #1708927
12/15/14 11:10 PM
12/15/14 11:10 PM
69HemiGTX Offline
69HemiGTX  Offline
Gotcha. I was thinking RC to truck. As far as the old vs. new bodies, that's a personal preference. I much prefer the old stuff to the new.
Re: Engine swaps for 72-80 trucks- max mileage [Re: 69HemiGTX] #1708928
12/16/14 12:29 AM
12/16/14 12:29 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I agree the 72-80 style is awesome, kind of a 71 Road Runner truck if you will. The 81 and newer are okay but just not cool enough.
Even a 93 318 or 360 Maggy truck 4X4 would make for a terrific donor, those Late Ramchargers are hard to find.
Sheldon
Re: Engine swaps for 72-80 trucks- max mileage [Re: RUNCHARGER] #1708929
12/16/14 01:45 AM
12/16/14 01:45 AM
Canada
demon Offline OP
demon  Offline OP
Canada
Exactly Sheldon. If you see any out your way, let me know. I'm looking around here for a good earl Ramcharger and /or a 92-93 truck or Ramcharger to use as a donor.
Re: Engine swaps for 72-80 trucks- max mileage [Re: demon] #1708930
12/16/14 02:39 AM
12/16/14 02:39 AM
RUNCHARGER Offline
RUNCHARGER  Offline
I'll let Dean know as well if you haven't already.
Sheldon
Re: Engine swaps for 72-80 trucks- max mileage [Re: RUNCHARGER] #1708931
12/16/14 01:09 PM
12/16/14 01:09 PM
Elk Grove, Calif.
bigblock340power Offline
Elk Grove, Calif.
I was kicking around the idea of snagging a rollover (some where in the 2000-2010 range for the Hemi/trans setup). Pulling the body off, and bolting mine on. I know, I put this way to simply, I'm sure theirs a bunch of things I'd need to do to get it to work. But wouldn't it be nice to have a newer Hemi setup under a '70s truck body?! Just what would be involved in this? Also, Calif. smog laws would be all over me. But my '76 has to be smogged anyway, and I'd have no problem smogging it to the newer truck specks. But would Calif. smog laws want it to pass smog for my '76 trucks year. I'd think the newer set up would do this no problem, except for the visual. I guess I'd have to talk it over with a ref. first.
Just a thought.
Re: Engine swaps for 72-80 trucks- max mileage [Re: bigblock340power] #1708932
12/16/14 03:30 PM
12/16/14 03:30 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
A new hemi into a truck would be no different then any car swap and pretty easy these days. However you'd still have mid 70's truck handling. Putting an older body onto the frame would be a ton of work but you'd have something that handled a bit better.
Re: Engine swaps for 72-80 trucks- max mileage [Re: demon] #1708933
12/16/14 10:48 PM
12/16/14 10:48 PM
Canada
demon Offline OP
demon  Offline OP
Canada
I just had an idea.
I got to checking wheelbases of Jeeps, thinking about frame swaps and such.
Turns out the the 93-2011 Grand Cherokee has the same wheelbase as a Ramcharger.
Hmmmm.
Track width is close too. The Jeep specs at 2" narrower track, but they also use positive offset rims. With some regular offset wheels the track should be just about right on.
So here's my new idea:
Buy a low mileage Grand Cherokee. Chop all the body off leaving only the floor and firewall on the underbody.
Chop all the floors out of the Ramcharger and lower the body onto the Jeep.
Fill in the gaps and voila! One fuel injected, overdrive, part time 4x4 with all the modern accesories and a 4.0 six, 5.2 V8 or 5.9 V8.
I have a friend who has built numerous body/Frame swapped vehicles in this manner.
I think I'll go looking for a mint Grand Cherokee to hack up.
Re: Engine swaps for 72-80 trucks- max mileage [Re: demon] #1708934
12/17/14 03:22 PM
12/17/14 03:22 PM
dogdays Offline
dogdays  Offline
You're out of your mind. Here come the guys in the white coats!
R.
Re: Engine swaps for 72-80 trucks- max mileage [Re: demon] #1708935
12/17/14 03:23 PM
12/17/14 03:23 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
The rear diffs are complete junk, most are full time 4x4 and most are 3.73 gears and are not know for there great MPG.
I think you would be better off making a dakota work under there with a V6 3.55s and 5 speed.
Re: Engine swaps for 72-80 trucks- max mileage [Re: demon] #1708936
12/25/14 01:58 PM
12/25/14 01:58 PM
Chicagoland
Cooter Offline
Cooter  Offline
Chicagoland
I just had an idea.
Hmmmm.
I don't know where you got your numbers, but the axles under a ZJ are 9 inches narrower than a RC. 60 1/2", just a hair wider than an early B body. Plus they are unibody, just like the aformentioned B body.
You might a well just hack apart a Coronet, and try to weld the RC to that.
