brake line sizing #1708765
12/10/14 12:10 AM
12/10/14 12:10 AM
Az
Crizila Offline OP
Crizila  Offline OP
Az
About to start designing a brake system for my 33. Going with AN stuff for the most part. Also thinking about plumbing it all in -3 ( 3/16" ) line. Any thoughts about using -4 ( 1/4" ) off the master and then down to -3 to the brakes? 4 wheel disc with GM calipers. Thanks, John
Fastest 300
Re: brake line sizing [Re: Crizila] #1708766
12/10/14 12:26 AM
12/10/14 12:26 AM
moparx Offline
moparx  Offline
are you contemplating using all braided line ? or just for the 3 flex points[both front wheels and the rear end]? or am i just missing the size [an] point ? as for the sizing, 3/16 is really all you need.
Re: brake line sizing [Re: moparx] #1708767
12/10/14 12:04 PM
12/10/14 12:04 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
On the line size, just wanna make sure I won't have any "volume" issues. Pretty sure 3/16" will be fine. Except for the flex points, the rest will be hard lined in 3/16".
Fastest 300
Re: brake line sizing [Re: Crizila] #1708768
12/10/14 02:03 PM
12/10/14 02:03 PM
dogdays Offline
dogdays  Offline
If we assume that the brake fluid is incompressible and the lines don't expand with pressure, then the volume you shove into one end of a filled line is the same volume that will come out at the other end, no matter what the size.
I don't believe I've ever seen 1/4" line on brakes.
The above assumptions are not 100% correct but they are close enough to work.
R.
Re: brake line sizing [Re: dogdays] #1708769
12/10/14 06:49 PM
12/10/14 06:49 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
10-4 on that. Thanks.
Fastest 300
Re: brake line sizing [Re: Crizila] #1708770
12/11/14 03:53 PM
12/11/14 03:53 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Volume versus velocity. Lots of older cars had 1/4" brake lines.
Re: brake line sizing [Re: Crizila] #1708771
12/11/14 05:05 PM
12/11/14 05:05 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I have used 3/16 steel line and #3 fittings on many scratch built dragsters that went 265 mph. They always stopped real well. It's all you need, imo.
Re: brake line sizing [Re: John_Kunkel] #1708772
12/11/14 05:45 PM
12/11/14 05:45 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Ya, kinda why I asked John. Assume most of them were drum/drum or disc/drum. Since this is a 4 wheel disc application, and I will be using two separate masters with 1" bores each, don't think I am going to have any volume issues. Pedal ratio will be 6.25:1 for this manual system, so pedal pressure shouldn't be to hi.
Fastest 300
Re: brake line sizing [Re: dogdays] #1708773
02/19/15 07:53 PM
02/19/15 07:53 PM
Montana
DDodger Offline
DDodger  Offline
Montana
R.
All hoses will expand "some" maybe not "much". But the larger they are the more they expand. I'd use no3 and keep hoses as short as possible.
