Turned the key and nothing? #1708734
12/09/14 10:34 PM
12/09/14 10:34 PM
california
sbcjd Offline OP
sbcjd  Offline OP
california
Went out to start the challenger today. It has been sitting since July. Turned the key and nothing--no click no sound at all. Put the 5 1/2 year old battery on a battery tender and after a couple of hours the tender shows its charged. Hit the key and still nothing. Where should I start checking. Thanks
Re: Turned the key and nothing? [Re: sbcjd] #1708735
12/09/14 10:40 PM
12/09/14 10:40 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Remove and clean both battery posts and cables first.
Re: Turned the key and nothing? [Re: Challenger 1] #1708736
12/09/14 10:49 PM
12/09/14 10:49 PM
california
sbcjd Offline OP
sbcjd  Offline OP
california
I cleaned the battery post and cable ends. Still no sounds.
Re: Turned the key and nothing? [Re: sbcjd] #1708737
12/09/14 11:07 PM
12/09/14 11:07 PM
Cincinnati, Ohio
Cincinnati, Ohio
Wiggle/check the 2 big plastic plugs under the steering wheel/coluum while having someone turning the key, if this is a old challenger?
Re: Turned the key and nothing? [Re: Challenger 1] #1708738
12/09/14 11:09 PM
12/09/14 11:09 PM
yellow70charger Offline
try starting in neutral
Re: Turned the key and nothing? [Re: sbcjd] #1708739
12/09/14 11:10 PM
12/09/14 11:10 PM
NE
moparpoolman Offline
NE
"Put the 5 1/2 year old battery on a battery"
How long do you think batteries last?
Dome light come on? If yes, try it in neutral
Re: Turned the key and nothing? [Re: sbcjd] #1708740
12/09/14 11:15 PM
12/09/14 11:15 PM
(1) pull the female connector/wire off of the "grn" terminal on the starter relay & with a jumper wire with alligator clips on each end ground the male lug on the starter relay to ground & see if it will crank/start with the key. (2) If it cranks, pull the 3 wire connector off of the side of the trans case & ground the center female pin in the connector you removed, to the trans case & see if it will crank/start. If it does then put the trans in park & ohm the center pin in the trans piece to the trans case & see if you have continuity. (4) if it wont crank (but did in (1) trace that wire back to the firewall bulkhead & seperate the bulkhead & check/clean those 2 brass terminals on either half. sometimes just seperating the halves then replacing em is enough to restore continuity. If it would not crank in (1) originally; with your meter or test light see if you have fire at the yellow wire female connector itself at the starter relay "ign" terminal while someone holds the key to start. If no fire check that pair of brass terminals in the bulkhead halves for the "start" circuit. www.mymopar.com has the colors for you. Short version: starter relay needs fire to the "ign" terminal for it to crank/starter relay "grn" terminal needs to be grounded in park/neutral. Holler back when you can
Re: Turned the key and nothing? [Re: RapidRobert] #1708741
12/09/14 11:44 PM
12/09/14 11:44 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Make sure the trans is safely in park if an auto or in neutral if a standard before jumping the starter relay.
Careful, your character's showing!
Re: Turned the key and nothing? [Re: sbcjd] #1708742
12/10/14 12:11 AM
12/10/14 12:11 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Step 1, does the dome light work? maybe it's not functional??? Turn on the headlights, Do they turn on and are bright???
IF not, check the battery and cables
IF they are, turn the key and see if they go out,
Report back
Re: Turned the key and nothing? [Re: TJP] #1708743
12/10/14 02:00 PM
12/10/14 02:00 PM
california
sbcjd Offline OP
sbcjd  Offline OP
california
First I want to thank you all for the tips. The car is a 1970 Challenger with a 440 engine and 727 transmission. It started just fine back in July. The dome light and head lights work. I will be checking some of the wiring today or tomorrow. Thanks again.
Re: Turned the key and nothing? [Re: sbcjd] #1708744
12/10/14 02:25 PM
12/10/14 02:25 PM
Houston, Tx
hemi68charger Offline
Houston, Tx
Carefully, try by-passing the started-relay switch on the driver's fender apron and see if the starter engages... Also, even though you may have lights, you may not have enough juice to engage any part of the starter circuit.
If it turns over that way, then I would start checking from there. Maybe it is the starter relay..
Troy
Houston Mopar Connection Club
Re: Turned the key and nothing? [Re: sbcjd] #1708745
12/10/14 03:45 PM
12/10/14 03:45 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
if the headlights remain bright when the key is turned your most likely candidates are:
The starter relay, the neutral safety switch, the wiring that connects them or linkage adjustment.
Try momentarily jumpering the two silver terminals with a heavy wire or screwdriver. If the starter engages it is one of the 3 above mentioned items
Report back
Re: Turned the key and nothing? [Re: hemi68charger] #1708746
12/10/14 04:03 PM
12/10/14 04:03 PM
california
sbcjd Offline OP
sbcjd  Offline OP
california
I tightened the nuts on the starter cables, tried the lights and they did not come on so I cranked on the battery ground cable nut and the lights came on. Turned the key and heard a sound behind the dash. Some sort of electrical sound. Put the battery tender to charge the battery and it is charging now. Yesterday it showed the battery fully charged. So maybe the battery is not holding its charge. May have to get a new battery. Back out to the garage.
Re: Turned the key and nothing? [Re: sbcjd] #1708747
12/10/14 05:53 PM
12/10/14 05:53 PM
Houston, Tx
Houston, Tx
When you're messing with the key to see if it'll crank, make sure you turn everything off so there's no noise being generated that might lead to an erronous diagnosis, like the heater fan motor, etc..
Troy
Re: Turned the key and nothing? [Re: sbcjd] #1708748
12/10/14 05:59 PM
12/10/14 05:59 PM
Cab_Burge Online work
Cab_Burge  Online Work
Check the battery voltage with a good volt meter, it should have a minumum of 12.25 volts after sitting from charging several hours If not replace it and then start your trouble shooting
Re: Turned the key and nothing? [Re: TJP] #1708749
12/10/14 07:21 PM
12/10/14 07:21 PM
california
sbcjd Offline OP
sbcjd  Offline OP
california
Ok, I took the starter relay shield off a used a large screw driver to short across the two silver post. The engine did not crank. So what is next?
Re: Turned the key and nothing? [Re: sbcjd] #1708750
12/10/14 07:36 PM
12/10/14 07:36 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Not even a click at the starter? Bad solenoid maybe.
Facts are stubborn things.
Re: Turned the key and nothing? [Re: larrymopar360] #1708751
12/10/14 07:41 PM
12/10/14 07:41 PM
Laveen, Arizona
GTSDart340 Offline
GTSDart340  Offline
Laveen, Arizona
Start with the easy stuff. Take the battery out and to the local parts store for a load test. If it tests good, then start looking into the starter and or relay.
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
Re: Turned the key and nothing? [Re: GTSDart340] #1708752
12/10/14 08:02 PM
12/10/14 08:02 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Did you check both ends of the ground cable?
Re: Turned the key and nothing? [Re: stumpy] #1708753
12/10/14 09:58 PM
12/10/14 09:58 PM
california
sbcjd Offline OP
sbcjd  Offline OP
california
No, I checked the end that bolts to the radiator support. I did not pull the intake manifold bolt end. I did replace the start relay and shorted the two posts. All I got was some sparking. No engine cranking. Guess I should have the battery tested or maybe I will go buy a new one. I will report my results. Thanks for all the help.
