Re: Turned the key and nothing?
[Re: sbcjd]
#1708735
12/09/14 10:40 PM
12/09/14 10:40 PM
Challenger 1
Cincinnati, Ohio
Went out to start the challenger today. It has been sitting since July. Turned the key and nothing--no click no sound at all. Put the 5 1/2 year old battery on a battery tender and after a couple of hours the tender shows its charged. Hit the key and still nothing. Where should I start checking. Thanks
Remove and clean both battery posts and cables first.
[Re: sbcjd]
#1708737
12/09/14 11:07 PM
12/09/14 11:07 PM
Challenger 1
Cincinnati, Ohio
Wiggle/check the 2 big plastic plugs under the steering wheel/coluum while having someone turning the key, if this is a old challenger?
[Re: sbcjd]
#1708740
12/09/14 11:15 PM
12/09/14 11:15 PM
RapidRobert
(1) pull the female connector/wire off of the "grn" terminal on the starter relay & with a jumper wire with alligator clips on each end ground the male lug on the starter relay to ground & see if it will crank/start with the key. (2) If it cranks, pull the 3 wire connector off of the side of the trans case & ground the center female pin in the connector you removed, to the trans case & see if it will crank/start. If it does then put the trans in park & ohm the center pin in the trans piece to the trans case & see if you have continuity. (4) if it wont crank (but did in (1) trace that wire back to the firewall bulkhead & seperate the bulkhead & check/clean those 2 brass terminals on either half. sometimes just seperating the halves then replacing em is enough to restore continuity. If it would not crank in (1) originally; with your meter or test light see if you have fire at the yellow wire female connector itself at the starter relay "ign" terminal while someone holds the key to start. If no fire check that pair of brass terminals in the bulkhead halves for the "start" circuit. www.mymopar.com has the colors for you. Short version: starter relay needs fire to the "ign" terminal for it to crank/starter relay "grn" terminal needs to be grounded in park/neutral. Holler back when you can
[Re: sbcjd]
#1708742
12/10/14 12:11 AM
12/10/14 12:11 AM
Posts: 15,545 Omaha Ne
TJP
Omaha Ne
Step 1, does the dome light work? maybe it's not functional??? Turn on the headlights, Do they turn on and are bright??? IF not, check the battery and cables IF they are, turn the key and see if they go out, Report back ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: sbcjd]
#1708744
12/10/14 02:25 PM
12/10/14 02:25 PM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Carefully, try by-passing the started-relay switch on the driver's fender apron and see if the starter engages... Also, even though you may have lights, you may not have enough juice to engage any part of the starter circuit.
If it turns over that way, then I would start checking from there. Maybe it is the starter relay..
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
[Re: sbcjd]
#1708747
12/10/14 05:53 PM
12/10/14 05:53 PM
hemi68charger
Houston, Tx
I tightened the nuts on the starter cables, tried the lights and they did not come on so I cranked on the battery ground cable nut and the lights came on. Turned the key and heard a sound behind the dash. Some sort of electrical sound. Put the battery tender to charge the battery and it is charging now. Yesterday it showed the battery fully charged. So maybe the battery is not holding its charge. May have to get a new battery. Back out to the garage.
When you're messing with the key to see if it'll crank, make sure you turn everything off so there's no noise being generated that might lead to an erronous diagnosis, like the heater fan motor, etc..
[Re: larrymopar360]
#1708751
12/10/14 07:41 PM
12/10/14 07:41 PM
Posts: 1,306 Laveen, Arizona
GTSDart340
Laveen, Arizona
Start with the easy stuff. Take the battery out and to the local parts store for a load test. If it tests good, then start looking into the starter and or relay.
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
