Re: Grinding a race crank
[Re: Airwoofer]
#1708298
12/08/14 06:21 PM
12/08/14 06:21 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Whats the issue with the crank... does it need a polishing or what... if your buying bearings for it already then its a good crank IMO.... plenty of guys are turning them down to some SMALL journal sizes.. way smaller than chevy
[Re: Cab_Burge]
#1708300
12/08/14 06:30 PM
12/08/14 06:30 PM
Posts: 19,361 Las Vegas
Al_Alguire
Las Vegas
Assume it is a 4.530" bore deal. Why does your engine builder want a different main and rod size? As stated plenty of cars out there running Honda or smaller rod journals, on the mains would depend on what the application was for me. But don't see how you will make them bigger???
IMO buy a new crank if he thinks wither are an issue. Sell what you have to someone who is looking to go with smaller journals.
[Re: Airwoofer]
#1708302
12/08/14 06:57 PM
12/08/14 06:57 PM
Nitride is for wear protection--who cares? Grind it using professional crank shop and keep rolling--if it was in a dirt car that was going to eat abbrasive all season yea nitride is a good thing but your engine will never know you cut through that crust--it won't care at all!!!! It will LOVE the fact that you now have round/true/untapered journals and an even fatter radius. I have cut about 65 440 cranks down to 383 mains and raced the SNOT out of them--Never ever an issue----Grind it--race it--Forget it! It will not wear unless it had dirt in there so .......
[Re: Al_Alguire]
#1708303
12/08/14 07:00 PM
12/08/14 07:00 PM
MR_P_BODY
I had a billet crank welded up, ground and nitrided.... sorry I had it welded up.. only needed to be turned .020.... but it was a new crank
[Re: Airwoofer]
#1708304
12/08/14 07:00 PM
12/08/14 07:00 PM
I don't have the numbers but he says it is too small. The motor had good oil pressure before it was taken apart so I have to wonder what's so bad about too much clearance?
This crank has been through that bad shop in Memphis and the journals have been polished too much I think. Problem is I am in the process of having pistons made for it that will also match the wore out 4.538 bore. The rings are expensive. With 47cc chamber heads I need 38cc dish and 0.060 in the hole to get 10-1 which is kinda high but usable with the side slinger blower. Could get a new crank but finding one with that same stroke may be tough. Any more stroke and it will take even more dish or further down in the hole. That would push the comp height.
I feel like I am trying to make a silk purse outta a pigs ear here.
Lots of Pigs Ear engines win races every season--in fact they are the most fun--winning with less than Perfect engines is the Normal--The perfect anal guys never sleep at night because they worry too much and can't win--Us Dumb racers put our " junk" together and never think of it again and can Concentrate on winning races
[Re: dvw]
#1708307
12/09/14 12:50 PM
12/09/14 12:50 PM
Posts: 655 Huntsville, AL
Airwoofer
Huntsville, AL
For what it's worth this is my 2 cents. A wise man said if you have too much bearing clearance you alone will know. If you don't have enough , everyone will know. As long as bearings are available or clearance isn't out of this world, it should work fine.Same with rings. 4.5035" file fit in your bore may work a blower motor wants a big gap anyway. I doubt it will know the difference. The biggest issue here is you are questioning your engine builder. You both need to be on the same page. If you don't trust what he's telling you asking on line is a crap shoot. Lots of knowledge, lots of misinformation, just need to know how to sift through it. Doug
I do trust this guy and we have a great working relationship, which is why my junk is in his shop. He says the crank needs turning which puts me in a spot. He is not a big machine shop. I do not know of a shop in this area (N Alabama) that I could trust to do the job right. LOL, he has mentioned Ohio Crankshaft but with the upcoming football game between OSU and Bama maybe not the best idea to send it up there . The cutting off of the nitride is also a concern to me but maybe that is false worry. I will find out what the actual numbers are and look at the old bearing shells. The darn thing may need straightening, I know a bunch of the balance holes are gonna need to be filled as I go from alum BME rods to steel Callies (and longer also) and there are a bunch of them holes.
Total Seal is suggesting 4.535 gapless top and second rings, 0.043 wide.
[Re: Airwoofer]
#1708311
12/09/14 01:34 PM
12/09/14 01:34 PM
Challenger 1
Cincinnati, Ohio
Send it to Flanakin crankshaft in Huston Tx. He does byrant work and for many pros. He has done 3 bryant cranks for me and fast like in one or 2 days. He can weld them or whatever you need. web page
[Re: GTS340]
#1708312
12/09/14 01:44 PM
12/09/14 01:44 PM
Airwoofer
Huntsville, AL
Does Huntsville engines not grind cranks? There are a few trustworthy places in Detroit.
I drive past their shop every day. Never see any work being done there besides wiring up tube racks. You should see the pile of cranks sitting on the floor. Gary Reavis is no longer there.
Thanks for the other ideas guys.
