Re: Engine R & R on 2002 and newer Ram trucks...
[Re: Kern Dog]
#1708105
12/08/14 11:48 AM
12/08/14 11:48 AM
Posts: 1,890 Spahn Ranch
RMCHRGR
Spahn Ranch
I was a Jeep/Chrysler/Dodge tech until 2012. We never took the cab off?? Not even the hood.
Take the radiator and shroud out, you're gonna drain the coolant anyway. Take off the accessories too, that frees up a lot of room.
Take the intake off and attach a chain to the heads. There's a couple places in the front or back of the heads to attach bolts to. Just make sure to take the slack out of the chain and put it diagonally across, should be OK. We used the intake bolt holes sometimes too.
Might want to look into a push rod holding fixture, you'll never get the valve train on correctly without it.
'71 Duster '17 Ram 1500
[Re: RMCHRGR]
#1708106
12/08/14 03:32 PM
12/08/14 03:32 PM
Guitar Jones
Yep what he said. Take the cross piece off the top of the core support area also. If you think this is fun try removing a Cummins in one of these trucks.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
