For the sparkplug readers- check these out
#1707004
12/05/14 03:32 PM
12/05/14 03:32 PM
Posts: 1,682 Philadelphia
radar
Philadelphia
What story do these plugs tell you? They are from two ten minute drives with a fresh motor- the cam was just broken in and I'm thinking the rings might not be seated yet. I do know that I forgot to get new gas and I was still burning up 7 month old gas that may or may not have had sta-bil put in it (oops!). Also the carb is not tuned but should be close-ish or maybe lean its from my last 408 and now sits on a victor 340 and ported edelbrocks instead of an air-gap and stock e heads. My thinking is either misfires on the clean ones or rings not seated yet and oil fouling the darker plugs. The heat range looks right on the straps and the rings all seem to say rich. Fuel distribution? It's a victor 340 intake. Here ya go: And a closeup/straight on view of #2 & #4 And a detail of #5 & #3
Re: For the sparkplug readers- check these out
[Re: Thumperdart]
#1707007
12/05/14 04:21 PM
12/05/14 04:21 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Normally aspirated engines just do that due to differences in wet air flow. EGT's can vary a lot across a carbureted motor, up to 100* or more on a few that I have worked on. Sequential EFI is one of the few ways that helps eliminate the difference because it balances out each cylinder based on how it is firing. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: radar]
#1707013
12/05/14 07:36 PM
12/05/14 07:36 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Get rid of the old fuel and install a new set of plugs... the old fuel CAN be down low enough(RVP, reed vapor pressure) that only in the hotter cyls its firing... what your looking at now is a waste of time
[Re: Monte_Smith]
#1707014
12/05/14 07:37 PM
12/05/14 07:37 PM
Quicktree
Okie dokie..............look at the above plugs and tell me which circuit needs work.........LOL!!!
Monte
with Monte, you can't tell crap cruzing
[Re: Crizila]
#1707018
12/07/14 01:52 AM
12/07/14 01:52 AM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
By the way Im not looking for a lean/fat evaluation- I am more curious about how some plugs are way cleaner
Fuel distribution would be my first guess.
Bingo! Fuel distribution, my Victor 340 does it at cruise.
