ring end gap? #170697
12/19/08 03:29 PM
12/19/08 03:29 PM
n.e. pa.
65rbdodge Offline OP
n.e. pa.
i putting together a stock rebuild 318. its a stock bore and the cyls. have been honed. i have a set of std. hastings moly rings, my end gap at both the top and bottom of the cyl. is .030, is this to much? do i need a different set of rings? the box says it should be a minimum of .015 but it doesnt say what the max should be.
Re: ring end gap? [Re: 65rbdodge] #170698
12/19/08 03:49 PM
12/19/08 03:49 PM
.004" per inch of bore on the top ring & .003 on the 2nd ring per inch of bore(for non KB hyper pistons), for you it'd be 15 tho & 11 thou. 30 is too much but it would work but it would work much better with a tighter set of moly rings or may even require the extra $$ for a file fit set. The amt of wear plus the honing opened it up a bit & since circumference = Pi X diameter, a .001" increase in dia(from the honing/wear) will increase the ring gap 3.14"
Re: ring end gap? [Re: 65rbdodge] #170699
12/19/08 03:54 PM
12/19/08 03:54 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
Way WAY toooo big IMO.
How much is your piston-to-wall ?
Re: ring end gap? [Re: 65rbdodge] #170700
12/19/08 04:34 PM
12/19/08 04:34 PM
New Mexico
dmerc Offline
dmerc  Offline
New Mexico
Perfect gap for nitrous, but a little too much for stock. Having said that I put rings in an engine that had been overbored by .002 and the top ring gap was .022. The engine ran fine and didn't smoke. If you are short on money put it together or get some file fit rings. Really sounds like a tired engine that needs to be bored out.
Re: ring end gap? [Re: 65rbdodge] #170701
12/19/08 07:37 PM
12/19/08 07:37 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Your cylinders must be worn a bit much, or you would not have such a strange fit of new ring set.
Re: ring end gap? [Re: dmerc] #170702
12/19/08 07:43 PM
12/19/08 07:43 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
The ring end gap is the least of your problems. I bet you have lots of cly taper and a large piston to cly wall clearance. If the motor should have been bored out and it wasn't, then you will have lots of clearance in those areas. I would not get file to fit rings because if you set it for the top and have lots of taper, you will be too tight at the bottom. The first tool an engine builder needs is a good set of mics and snap gauges( or dial bore gauge).You will use them for the rest of your life. If you have .005 or more taper, then put it together and save for some pistons and a bore job later. Mark
Re: ring end gap? [Re: fastmark] #170703
12/19/08 08:55 PM
12/19/08 08:55 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Did you check and measure the gap in a bunch of spots up and down the bore? You can set the gap at the tightest point. I use the ring manufacturers recommended gap, or the KB adjustment for them. I also ad about 5% tothe second ring gap. You dont want it as tight as the top ring.
Re: ring end gap? [Re: 65rbdodge] #170704
12/19/08 09:14 PM
12/19/08 09:14 PM
N.E.Ohio
P
pacifica Offline
pacifica  Offline
P
N.E.Ohio
.030 is more than you would want in a
"good" rebuild. But if you are doing an "economy" overhaul then it will work, although it will probably use a little more oil than you'd like.
Re: ring end gap? [Re: fastmark] #170705
12/20/08 12:33 AM
12/20/08 12:33 AM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
cylinder taper ? ... ?
With 030 ring gap and both bottom and top? I will bet that he might have near or over .010 piston-top-wall.
Not good.
Re: ring end gap? [Re: 65rbdodge] #170706
12/20/08 01:08 AM
12/20/08 01:08 AM
Western Michigan
68Fastback Offline
68Fastback  Offline
Western Michigan
Did you file the rings to that dimension or is that what you are getting with them in the bore. By chance did you measure the bore thru the intended stroke.
Re: ring end gap? [Re: 65rbdodge] #170707
12/20/08 01:32 AM
12/20/08 01:32 AM
MR_P_BODY Offline
MR_P_BODY  Offline
.030 is way too much. Are you using the original
piston that were in it? I'd be looking for a bore
job on it and a set of KB pistons or any other
inexspensive set(if your going inexspensive) and a
set of rings. If you put it together like that you
wont be happy at all, its going to have alot of blow by
and soon you will be pulling the engine AGAIN and
I dont think any of us cares to do this(most dont)
Re: ring end gap? [Re: MR_P_BODY] #170708
01/01/09 03:44 PM
01/01/09 03:44 PM
Western Michigan
68Fastback Offline
68Fastback  Offline
Western Michigan
Any update on your situation.
