426 Hemi Minimum Valve Clearances
#1706775
12/05/14 04:08 AM
12/05/14 04:08 AM
Posts: 2,431 USA
SSAAHemiFan
USA
I have to bore notch a OEM block and increase the radial clearance for the intake valve in the piston What would be the acceptable minimum valve to bore clearance (seated and open)? and what would be the minimum valve radial clearance in the piston notch ? It's a street engine - 4.27 bore - 2.30 intake valve - hyd cam .551/.533 and approx .235@50The larger intake valve is making everything pretty cozy... I have found varying recommendations in the MP books and some generic recommendations on engine forums - some say the older recommendations were "generous and possibly outdated today" Bottom line - I wan't to make 100% sure it lives but I don't have enough room to go overboard on the specs either. Hoping I don't end up with some more expensive mistakes Thanks
Re: 426 Hemi Minimum Valve Clearances
[Re: SSAAHemiFan]
#1706776
12/05/14 07:57 AM
12/05/14 07:57 AM
Posts: 41 Northern MN
cedarmachine
Northern MN
I like to see .080” on the intake and .100" on the exhaust, in line. I would say no less than .060" radially, at the closest rocking point. Between piston rock and valve flex, error on the side of caution. Those big valves with small stems are like pendulums at high rpm.
[Re: cedarmachine]
#1706777
12/05/14 02:28 PM
12/05/14 02:28 PM
Posts: 2,645 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Using the stock head gasket as a template, if you take the Sunnen AN-980 chamfering cone and put a radius on the cylinder for the intake valve you will have plenty of radial clearance. And I can't believe a cam of that lift is going to hit anything.
2011 Drag Pak Challenger
[Re: Cab_Burge]
#1706779
12/06/14 04:48 AM
12/06/14 04:48 AM
Posts: 2,431 USA
SSAAHemiFan
USA
The checking springs and clay are this weekends fun. Rick thanks for the tip on using the cone for the bore relief - looks alot easier and faster than trying a die grinder and a carbide. Right now I only have .003 to the bore so I already new I would be cutting
