Page 1 of 9 1 2 3 4 5 6 7 8 9
Thumper carb first impression #1706258
12/03/14 10:23 PM
12/03/14 10:23 PM
Charleston
sixpackgut Offline OP
Drag Week Mod Champion
Charleston
The good :Its running smoother, feels much snappier, feels like its pulling harder and smells cleaner
The bad: I should have done this sooner
The unknown: taking it to the track Saturday and see how it does straight from Thumper. A 2 tenths increase will put me in the 9.80s and I think it could happen.
Re: Thumper carb first impression [Re: sixpackgut] #1706259
12/03/14 10:28 PM
12/03/14 10:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
So we have a pro carb tuner on the board.. thats cool,
I wonder what he is flowing these carbs on.. or is
it a guess
Re: Thumper carb first impression [Re: sixpackgut] #1706260
12/03/14 10:31 PM
12/03/14 10:31 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Can`t wait to see your results and if your 60 ft`s there you will fly.............
Re: Thumper carb first impression [Re: MR_P_BODY] #1706261
12/03/14 10:31 PM
12/03/14 10:31 PM
Charleston
Charleston
it a guess
Whatever he is doing he is doing a good job at it. We will get a verdict on sat on mine
Re: Thumper carb first impression [Re: Thumperdart] #1706262
12/03/14 10:32 PM
12/03/14 10:32 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Dom send me your info. and what you need from me.. I'll be sending you mine soon...
Coming soon!!!!
Re: Thumper carb first impression [Re: MR_P_BODY] #1706263
12/03/14 10:37 PM
12/03/14 10:37 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
it a guess
What`s to flow, that`s built in I`m just maximizing the potential of all of the screwed up holley tune ups. Don`t hate and I`m no expert Mike just learning what works and what doesn`t and I`ll bet I can fix yours if it`s the same as 99% of the ones I`ve seen.........
Re: Thumper carb first impression [Re: Mr.Yuck] #1706264
12/03/14 10:38 PM
12/03/14 10:38 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Call me anytime............760-900-3895...........
Re: Thumper carb first impression [Re: Thumperdart] #1706265
12/03/14 10:39 PM
12/03/14 10:39 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
You do now the top carb shops do not give CFM ratings right?? They will give you the throttle blade, venture and booster sixe though. A WHOLE lot more to a carb than just a flow number.
Re: Thumper carb first impression [Re: Al_Alguire] #1706266
12/03/14 10:43 PM
12/03/14 10:43 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Totally............this stuff is deeper than most can imagine and carbs are a way complex yet tuner friendly device..........
Re: Thumper carb first impression [Re: Al_Alguire] #1706267
12/03/14 10:44 PM
12/03/14 10:44 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
I have found that flowing them on the bench and balancing the booster signals can fix some issues. Just Saturn's
Keith
Re: Thumper carb first impression [Re: Thumperdart] #1706268
12/03/14 10:48 PM
12/03/14 10:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
it a guess
I'm injected now... it takes care of itself.. good
luck with the carb stuff... by the way.. when I did
it at work we used a flow bell(flow bench with a lid
to set the barometric pressure)
Re: Thumper carb first impression [Re: Dunnuck Racing] #1706269
12/03/14 10:56 PM
12/03/14 10:56 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Keith
No doubt but first fix the obvious tune up "issues" and go from there. Only one carb had some miss aligned boosters and I fixed em............did it make it better? Don`t know that it was a problem in the first place.............
Re: Thumper carb first impression [Re: MR_P_BODY] #1706270
12/03/14 11:04 PM
12/03/14 11:04 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
it a guess
I know you spent time in the lab and that`s cool and you guys paved the way Mike but seems what worked good back then has gotten crazy. Very few cars I know of need more than a 2-circuit carb or 2-3 emulsion holes not 4-5 wackin out the fuel curve and makin em rich down low and lean up top.........just ask Ray. Anyhow, like everyone before me who figures stuff out w/the help of smarter people and applies it and PROVES it works, gets nut kicked so whatever but to the smart ones who try these tunes, thankxxx...........
Re: Thumper carb first impression [Re: Thumperdart] #1706271
12/03/14 11:09 PM
12/03/14 11:09 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Good job thumper, it's all the small things that make a car a outstanding performer.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Thumper carb first impression [Re: Thumperdart] #1706272
12/03/14 11:12 PM
12/03/14 11:12 PM
Northern Indiana
Northern Indiana
Just so you know Dom, I'm not knocking your work. You may know more about them than I do. I was just throwing a suggestion out there as I owe you a phone call.
I have seen a couple fuel distribution issues that were related to boosters.
Just about every 4 barrel I have tested had one booster lacking behind the others.
I just work backwards from how you are doing it.
Keith
Re: Thumper carb first impression [Re: Thumperdart] #1706273
12/03/14 11:20 PM
12/03/14 11:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Dom I'm sure you will agree that a production carb
is MUCH closer to being right.. your playing with
all aftermarket carbs and yes they are fat in the mid
Re: Thumper carb first impression [Re: MR_P_BODY] #1706274
12/03/14 11:26 PM
12/03/14 11:26 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Thankxxx guys. The older holleys w/the lowered ifr`s and 2-emulsion holes per side were WAY better but don`t sell me short Mike. I made a 750 speed demon completely tuneable that wouldn`t even rev past 5200 now goes to 6200 and he`s blown away and went from 15 mpg to 17 fwiw. Cleaner plugs and less "catch-up" time from a poorly tuned/working carb. Anyhow, you`ll see Ray`s and everyone else`s lower et`s and happy plugs. Gotta go and .............
Re: Thumper carb first impression [Re: MR_P_BODY] #1706275
12/03/14 11:33 PM
12/03/14 11:33 PM
Charleston
Charleston
My carb would go lean at wot. It was ok everywhere else. It rained here almost everyday this summer so I didnt get to spend any time on it plus I built another bad azz vehicle over the summer so Dom fixed what would have takin me months to figure out
Re: Thumper carb first impression [Re: Dunnuck Racing] #1706276
12/03/14 11:36 PM
12/03/14 11:36 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Keith
No offense taken and your right and all the dommies get a 12 hole booster insert and are dialed in bitchen on my car. I`ll get a flow bench if/when needed but for now I`m just making good ones better through the tune-ups I read about and apply. Also been studying wet flow stuff and really discovering what a crazy maze of channels and holes the metering block has and how fuel flow, weight height etc. affect the fuel curve. Gotta go..............
Re: Thumper carb first impression [Re: sixpackgut] #1706277
12/03/14 11:38 PM
12/03/14 11:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Ray I'm not taking anything away from Dom... but one
size doesnt fit all... we used 100,000 dollar set ups
to dial this stuff in... and tons of dyno hours
