Re: 68 Dodge b-body Windshield Clips
[Re: 68CoronetRT]
#170611
12/19/08 01:04 PM
12/19/08 01:04 PM
Posts: 6,391 Abilene, Texas
fastmark
Abilene, Texas
The clips are different. Some early 68 cars have different clips than the later clips. I found out the hard way on that. I had to get the windshield pulled out just to change the clips. Call Tom at R/T specialties. It is best to have your old clips in hand to be sure. Or you could order both.
[Re: 68CoronetRT]
#170615
12/19/08 09:05 PM
12/19/08 09:05 PM
68 can be a tricky year but here you go most b-bodies 68-70 use this at the bottom 10 required
#170616
12/19/08 09:06 PM
12/19/08 09:06 PM
however a few 68 b-body,s will use this one at the bottom 10 required
#170617
12/19/08 09:08 PM
12/19/08 09:08 PM
front sides and top will use this one 14 required
(this also fits 68-70 charger rear)
#170618
12/19/08 09:10 PM
12/19/08 09:10 PM
rear window all 68-70 b-body uses this one 20 required (except charger)
