Re: Piston very tight on connecting rod, how to fix?
[Re: Charger446]
#1705418
12/01/14 01:36 PM
12/01/14 01:36 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Since you havent tried anything and its been sitting for years I'd spray them first with wd-40 or something and see what happens
[Re: Charger446]
#1705423
12/02/14 01:44 PM
12/02/14 01:44 PM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
Got it! I was thinking the exact opposite. This gives me some hope. Having said this, I sprayed the penetrating oil on the wrong part. I will hit them again where the pin contacts the piston.
Did you look at the other seven?
[Re: Charger446]
#1705425
12/02/14 02:52 PM
12/02/14 02:52 PM
dogdays
When the piston heats up it expands and those tight pistons will be just fine. That's as long as you can move them by hand. That's my R.
[Re: Cab_Burge]
#1705427
12/04/14 11:14 AM
12/04/14 11:14 AM
Posts: 282 Northeast MA
Charger446
Northeast MA
That's my
R.
WD 40, Water Dispersment Formula # 40, is a rust preventive that evaporates, it is not a very good lubricant so try using light weight oil(ATF ) on the pins sqirted in from the outside of the pistons and then heat the piston wrist pin bosses up ( I use a heat gun or hair dryer depending on how hot I want to get the part)so the oil will soak in and help you free the pins up by rotating and flushing the gunk out with more oil
I spent some time last night on 2 of the pistons, used a heat gun as suggested above and kept squirting PB blaster on the sides, after about 5 minutes on each, I got them pretty loose and floppy, I could easily move it back and forth and side to side with little effort. Very excited about that!
However went into the garage this morning to go to work and checked them again and they were tight again as they were last night
I didnt use any other oil as suggested above yet, thats my next plan, to heat them up again, work them for another 5 to 10 min then oil them with a bit of light oil.
Then Ill move on to the last piston which was the tightest of the 3 but still moves.
[Re: dogdays]
#2786035
06/16/20 02:19 PM
06/16/20 02:19 PM
Charger446
Northeast MA
Yes, I realize this thread is 6 years old but after basically tearing the top end of this engine down a few times I think this issue is the source of my engine noises. After posting this thread, I brought the pistons/rods to the machine shop and asked them to disassemble, and loosen them up a bit to match the others. I always had the tapping sound since I put the engine together. I didn't take it to the track yet or have it dyno'd so I don't know if this issue is impacting performance. I did swap out the cam, lifters, rockers and push rods (measured for custom length) and nothing changed this sound. I then started pulling spark plug wires on the cylinders that had the tight pistons and wouldn't you know it, the noises went away!! So is it reasonable to think that now the pins in those rods are now loose and contributing to these noises? I really don't want to pull the engine out until winter when I have more time, what could happen here, anyone know from experience? I'm guessing it will get louder and louder until BANG! This engine is basically a place holder while I plan the next engine build (will be done by a pro, not me lol) https://www.youtube.com/watch?v=rFh6mxFDMrE
[Re: Charger446]
#2786124
06/16/20 07:51 PM
06/16/20 07:51 PM
Posts: 43,255 Bend,OR USA
Cab_Burge
Piston slap., wrist pin noise and exhaust gasket leaks sound a lot alike, I can't tell what your noise is on here, sorry As far as making the noise your hearing go away by you pulling the spark plug wires off the bad cylinders makes me think it is piston slap your hearing Does it get louder or quieter when it is warmed up? If quieter it is probably piston slap Is there oil on that spark plug?
[Re: Charger446]
#2786282
06/17/20 09:57 AM
06/17/20 09:57 AM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
To me, that noise sounds like tappet noise, like one or more of your hydraulic lifters is collapsing.
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
