Less money than I thought. Maybe I will change it at 80,000 miles.
If I could ask, where did you get it and what was the part number? The part number may depend on the engine serial number although, I could be wrong.
From what I could find the Cummins part is several hundred while the chinese imports are around $95.00.
The Monaco's actually are pretty good rigs once you learn how to work on them. If you have an issue with your throttle control I may be able to help. That one was a real expensive pain.
