451 stroker...real hp numbers
#1704850
11/30/14 05:21 AM
11/30/14 05:21 AM
Posts: 11,632 SHELBY TWP,,MICHIGAN
72N96RR
I LOVE WEDGIES
I LOVE WEDGIES
In reality what horsepower numbers can be achieved from a 451 stroker on pump gas and or race gas. With a compression ratio in line to prevent part breakage or constant maintenance..Torque numbers ?? This came by fedex yesterday for my low deck build...
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free.. If they come back it means nobody else wanted them either..!!
Re: 451 stroker...real hp numbers
[Re: 72N96RR]
#1704851
11/30/14 08:38 AM
11/30/14 08:38 AM
Posts: 10,015 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Cheap 451 stroker, Hypereutectic pistons, 9.5 compression, bowl ported 906 heads, 1 7/8 headers, 3310 holley on an M1 single plane, made 523 hp at 5800 rpm, wild hydraulic cam.
[Re: AndyF]
#1704853
11/30/14 04:28 PM
11/30/14 04:28 PM
72N96RR
I LOVE WEDGIES
I LOVE WEDGIES
MM magazine did a 452 build with single plane and 11.5 compression and hyd roller and achieved 675 hp... Id be more than pleased with 550 to 600hp with a motor that was dependable...
[Re: 72N96RR]
#1704854
11/30/14 04:33 PM
11/30/14 04:33 PM
Posts: 559 Idaho
LaRoy Engines
Idaho
In reality, 720-780HP, 500+ lb-ft from 3500 rpm to 7500 rpm on 91-93 octane with Edelbrock RPM heads, Indy single plane and a single 1100cfm Dominator.
[Re: LaRoy Engines]
#1704856
11/30/14 05:05 PM
11/30/14 05:05 PM
72N96RR
I LOVE WEDGIES
I LOVE WEDGIES
Id like to stick with the crossram for obvious reasons!! Id love some carb and head recommendations for the motor at 600hp..
[Re: 72N96RR]
#1704857
11/30/14 06:23 PM
11/30/14 06:23 PM
Posts: 43,277 Bend,OR USA
Cab_Burge
The first low deck 383 C.I. non stroker street motor I built a long time ago, when those intakes where avaible new(circa 1972)used a stock set of early iron heads (we did put 1.74 exhaust valves in them )the customer had and a Isky 505T solid roller cam. He had the intake with a set of early Holley6 50 DP carbs, that combination with a stock converter was a big dead dog under 3000 RPM The customer had promised me before starting the build he would buy a good race converter, electric fuel pump and good ignition also. He didn't That motor was a rocket ship between 3000 and 8500 RPM Knowing what I know now I would put a set of Holley 750 D.P. on that intake and be prepared to rejet and possibly mod the carbs. idle circiuts and power valves to meet the needs of the motor to drive and idle nice On the cam a solid roller with between 250 and 264 degrees @.050 with 106 to 110 LSA with as much lobe lift you can get would be my choice, the converter size and stall speed would determine the LSA and where I installed the intake lobe center in reference to TDC Last thing on the heads is to buy the best ones you can afford, CNC Eddy RPM would be my choice for that intake You might want to try soem spacers under the carbs after you get it going, try one to two inch at first
[Re: 72N96RR]
#1704858
11/30/14 08:36 PM
11/30/14 08:36 PM
Posts: 559 Idaho
LaRoy Engines
Idaho
As to carburetors, I've no experience with duals and those manifolds so silence is my best option.
Cylinder heads only need to be any iron or aluminum head that will get you 285cfm @ .500" lift and 295cfm @ .600" lift. So that would be any ported 902, 906, 915, 213, 346, 452 or a service prepped RPM or Stealth.
[Re: 383man]
#1704862
12/01/14 11:06 PM
12/01/14 11:06 PM
72N96RR
I LOVE WEDGIES
I LOVE WEDGIES
All terrific info but it sure is not an easy decision on which direction to go... Street to strip time would be 75/25 percent.. Ive assembled several motors in stock form so I am embarrassed to say my high performance knowledge is lacking ...But I am learning quickly thanks to friends, builders and info from you guys... Im sure I want what most would like..A reliable pump gas motor that sounds like it belongs on the strip yet can be driven easily on the street. Doesn't dip in your wallet every week..But when the loud pedal drops you can see some air under the front tires... And has a ten as the first number on the ET time slips...
