Page 9 of 9 < 1 2 3 4 5 6 7 8 9
#2061192 - 04/24/16 11:45 PM Re: Another Gen-III Hemi E-body swap [Re: GoodysGotaCuda]
ntstlgl1970 Offline
Loc: Sac, CA, USA
The ms3 is supposed to run it via pwm on the main board injector output but I don't think the frequency is high enough, still doing research...this alternator uses a positive voltage signal vs. the older ones that ground the field
#2063806 - 04/29/16 01:05 AM Re: Another Gen-III Hemi E-body swap [Re: ntstlgl1970]
ntstlgl1970 Offline
Loc: Sac, CA, USA
I weighed the car tonight, the weight balance front to rear is better than I thought it would be an improves with me in the car
#2063928 - 04/29/16 10:21 AM Re: Another Gen-III Hemi E-body swap [Re: ntstlgl1970]
Mopar Mitch Offline
Loc: NW Chicago suburban area
ntstlgl1970 -- Did you disconnect the sway bar end links when you did the weight scaling? Try doing that and then re-weigh as you might find differences.... then re-attach the sway bar end links equally by shimming each end, assuming they are typical stock-style (pending your sway bar end link designs). Also, be certain tire pressures are where you want them to be, and of course with driver's weight included at the driver's seat.
#2064498 - 04/30/16 12:53 AM Re: Another Gen-III Hemi E-body swap [Re: ntstlgl1970]
ntstlgl1970 Offline
Loc: Sac, CA, USA
I did not disconnect the end links since I was interested in seeing the total weight and f/r balance. I will try that though
Thanks!
#2404849 - 11/17/17 03:59 AM Re: Another Gen-III Hemi E-body swap [Re: ntstlgl1970]
HP2 Offline
Loc: Right here
Any updates? I'm curious as hell, just started a 6.1 swap!
68 Dart GT ht project. Hemi clone..?
70 W100 Power Wagon. 318 4-spd
70 'Cuda vert 340 clone, In Violet, white interior and top
70 'Cuda 383 project.
70 Sport Fury 440 2dr HT, will get that 6.1 Hemi...
71 Charger Super Bee - 383/727
72 Charger "Sabotage" - 440/727 - Street/Strip
#2409041 - 11/26/17 08:15 AM Re: Another Gen-III Hemi E-body swap [Re: ntstlgl1970]
AeroMonte Offline
Loc: S.E. Missouri
I'm starting a Hellcat swap into a 71 Cuda right now too. lots of learning to do
#2409190 - 11/26/17 02:28 PM Re: Another Gen-III Hemi E-body swap [Re: ntstlgl1970]
Frankenduster Offline
Moparts proctologist
Loc: Granite Bay CA
Eric is still alive but he is not as active here or elsewhere.
#2420808 - 12/19/17 12:32 AM Re: Another Gen-III Hemi E-body swap [Re: Frankenduster]
ntstlgl1970 Offline
Loc: Sac, CA, USA
I haven’t checked in for a while, but I’m still around. Need to get a pro to tune the engine and finish the interior
Edited by ntstlgl1970 (12/19/17 12:34 AM)
25,629 Registered Members
195,557 Topics
70’s vans...latest obsession.
by FrankenScamp
12/12/18 01:57 PM
Which throttle cable
by Youngblood
12/12/18 01:46 PM
727 front clutch clearance question?
by 451Mopar
12/12/18 01:41 PM
NHRA Stock Eliminator budget friendly?
by Roughbird72
12/12/18 12:37 PM
