Page 9 of 9 1 2 3 4 5 6 7 8 9
Re: Another Gen-III Hemi E-body swap [Re: GoodysGotaCuda] #2061192
04/25/16 01:45 AM
04/25/16 01:45 AM
Sac, CA, USA
N
ntstlgl1970 Offline OP
N
Sac, CA, USA
The ms3 is supposed to run it via pwm on the main board injector output but I don't think the frequency is high enough, still doing research...this alternator uses a positive voltage signal vs. the older ones that ground the field
Re: Another Gen-III Hemi E-body swap [Re: ntstlgl1970] #2063806
04/29/16 03:05 AM
04/29/16 03:05 AM
Sac, CA, USA
N
N
Sac, CA, USA
I weighed the car tonight, the weight balance front to rear is better than I thought it would be an improves with me in the car
Re: Another Gen-III Hemi E-body swap [Re: ntstlgl1970] #2063928
04/29/16 12:21 PM
04/29/16 12:21 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
ntstlgl1970 -- Did you disconnect the sway bar end links when you did the weight scaling? Try doing that and then re-weigh as you might find differences.... then re-attach the sway bar end links equally by shimming each end, assuming they are typical stock-style (pending your sway bar end link designs). Also, be certain tire pressures are where you want them to be, and of course with driver's weight included at the driver's seat.
Re: Another Gen-III Hemi E-body swap [Re: ntstlgl1970] #2064498
04/30/16 02:53 AM
04/30/16 02:53 AM
Sac, CA, USA
N
N
Sac, CA, USA
I did not disconnect the end links since I was interested in seeing the total weight and f/r balance. I will try that though
Thanks!
Re: Another Gen-III Hemi E-body swap [Re: ntstlgl1970] #2404849
11/17/17 06:59 AM
11/17/17 06:59 AM
Right here
HP2 Offline
HP2  Offline
Right here
Any updates? I'm curious as hell, just started a 6.1 swap!
70 W100 Power Wagon. 318 4-spd
70 Sport Fury 440 2dr HT
71 Duster 340
71 Charger Super Bee - 383/727
72 Charger "Sabotage" - 440/727 - Street/Strip
78 Warlock in beautiful patina
Re: Another Gen-III Hemi E-body swap [Re: ntstlgl1970] #2409041
11/26/17 11:15 AM
11/26/17 11:15 AM
S.E. Missouri
AeroMonte Offline
AeroMonte  Offline
S.E. Missouri
I'm starting a Hellcat swap into a 71 Cuda right now too. lots of learning to do
Re: Another Gen-III Hemi E-body swap [Re: ntstlgl1970] #2409190
11/26/17 05:28 PM
11/26/17 05:28 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Eric is still alive but he is not as active here or elsewhere.
Re: Another Gen-III Hemi E-body swap [Re: Kern Dog] #2420808
12/19/17 03:32 AM
12/19/17 03:32 AM
Sac, CA, USA
N
N
Sac, CA, USA
I haven’t checked in for a while, but I’m still around. Need to get a pro to tune the engine and finish the interior
