Re: Wilwood rear disc brake kits
[Re: bigtimeauto]
#1704153
11/28/14 01:06 AM
11/28/14 01:06 AM
Posts: 3,416 Toronto
mshred
Toronto
Wondering how many here have installed them (the ones with the parking brake) on a MOPAR REAR AXLE and if they ran into ANY issues at all? Whether it be during installation, or afterwards?
I have done 2 on Dana's without any issues at all. if you have the tapered bearing make sure you install the bearing bracket with the lip towards the bearing. Just make sure your axles have a access hole or it will be a pain to put them on. Actually I have never had a issue or even heard of any with wildwood stuff.
I am running the green bearings. Have you installed some with green bearings before Bob?
I don't think my axles have an access hole on them which is another problem. Not sure how hard it is to get them drilled out and to what size the hole needs to be.
[Re: DoctorDiff]
#1704157
11/28/14 02:48 AM
11/28/14 02:48 AM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
Wilwood Mopar rear discs with drum parking brake will only install easily if...
1. You order the kit for 2.36" axle offset and SNAP-RING Green bearings
2. You have aftermarket axles, access holes in the flange, 1/2" SCREW-IN lug studs with narrow hex-heads and very thin washers
3. You remove the thurst block inside the differential
Otherwise, machining is required.
...Then, you are on your own for the parking brake cables.
lokar makes the brake cable kit:
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: bigtimeauto]
#1704162
11/29/14 06:09 PM
11/29/14 06:09 PM
mshred
Toronto
Does the hole in the axle flange need to be drilled by a machine shop or can I get the job done at home with the right bit?
Also, what exactly is a thrust block?
And when deciding which offset, do you just go to the closest offset you currently have, or does it matter if the offset is more or less then yours i.e. 2.36 or 2.5....which to choose from if your offset is somewhere in the middle?
the block is in the center of stock style open end and posi units that the axles bottom out against. then the axle free play gets adjusted to keep the proper preload on the stock tapered bearing. Do you have a stock posi?
I am running a stock Dana 60 powerlock with 35 spline guts, so I am guessing I have a thrust block in my diff?
[Re: DoctorDiff]
#1704165
11/29/14 07:25 PM
11/29/14 07:25 PM
mshred
Toronto
Because Wilwood did not design any of their Mopar rear brakes correctly, you must use the kit advertised as 2.36", even though no Mopar axles were made with that offset.
If you order any kit advertised for use with "Mopar Performance Green bearings" or any other offset, you will really open a can of worms.
You can drill the axle flange with a hole-saw.
Does it matter if I am currently using B-Body backing plates? Or that has no bearing on what kit I use since axle offset that matters is WITHOUT the drum backing plates?
[Re: justinp61]
#1704166
11/29/14 07:25 PM
11/29/14 07:25 PM
mshred
Toronto
When I ordered my S-60 from strange I made sure there was a hole in the axle flange to get to the retainer nuts. I had the Mosers that were in my 8 3/4 drilled at a local machine shop.
Do you know which offset your kit is? Did you have any issues with the install? Stock posi?
[Re: mshred]
#1704168
11/30/14 04:56 AM
11/30/14 04:56 AM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
"I am running a stock Dana 60 powerlock with 35 spline guts, so I am guessing I have a thrust block in my diff?"
What axle bearings do you have? The block is for the stock tapered roller bearings with a adjuster on only one side.
"Just a Bracket car dressed up like a streetcar"
