Question about moving springs into frame rails. #170412
12/18/08 11:12 PM
12/18/08 11:12 PM
Midland, Tx
rjones Offline OP
rjones  Offline OP
Midland, Tx
68 dart with super stock springs and I am moving the springs into the frame rails. Got ready to drill hole for rear spring shackle mount and I notice there is a already a hole in the frame rail but is forward about 1/2" from the stock location. It looks as if the shackle needs to be moved forward with the super stock springs anyway and I wandered if anyone else had used this hole? Has anyone else encountered this problem?
Thanks,
Roger
Re: Question about moving springs into frame rails. [Re: rjones] #170413
12/19/08 07:36 AM
12/19/08 07:36 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
When we did my Valiant I got some thick wall tubing and used those holes w/no bushing.
When they did my old Dart they used thin wall tubing and bushings in those holes.
Re: Question about moving springs into frame rails. [Re: slantzilla] #170414
12/19/08 09:46 AM
12/19/08 09:46 AM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
when i did my 71 dart 4 door i used those holes. i welded a washer to both sides of the frame too to reinforce it.
Re: Question about moving springs into frame rails. [Re: 65rbdodge] #170415
12/19/08 01:44 PM
12/19/08 01:44 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
