Oil blowing out of breather #1704014
11/27/14 07:20 PM
11/27/14 07:20 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
Oil is blowing out the breather located in the left valve cover. Its enough to puddle on the floor after I drive the car for about 5 or more miles. What is causing this and how do I fix it?
Re: Oil blowing out of breather [Re: frank] #1704015
11/27/14 07:25 PM
11/27/14 07:25 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Do you have a pcv valve on the car?
Are the baffles in the valve covers?
Re: Oil blowing out of breather [Re: frank] #1704016
11/27/14 07:40 PM
11/27/14 07:40 PM
Cab_Burge Online work
Cab_Burge  Online Work
Crankcase pressure is the only reason that oil will be blown out of the breather caps Two possible causes, possibly a combination of both. First one is a plugged PCV valve , the other is bad ring seal. Remove the breather cap and PCV and start the motor up, let it get warmed up and then revved the motor up from idle to around 4000 RPM several times rapidly, if the smoke from the valve covers increases each time you rev it up it is blowby Let us know what you find, also has this motor set for a long time before you started driving it? A very simple way to check the PCV valve is to put your finger over the hole in the bottom with the motor running, if the idle speed decreases it is working, your plugging a metered vacume leak If it doesn't change the idle speed it, the PCV valve or hose, is plugged up Let us know what you find
Re: Oil blowing out of breather [Re: moparpollack] #1704017
11/27/14 07:54 PM
11/27/14 07:54 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
No PCV valve and the valve covers have baffles
Re: Oil blowing out of breather [Re: frank] #1704018
11/27/14 08:29 PM
11/27/14 08:29 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
sounds like it's time for a cylinder leak down test.
Re: Oil blowing out of breather [Re: lewtot184] #1704019
11/27/14 09:57 PM
11/27/14 09:57 PM
Ft. Wayne, IN.
Q
QTR MILR Offline
QTR MILR  Offline
Q
Ft. Wayne, IN.
Could be a bad head gasket.... Been there done that...
Scott
69 Satellite, 3650lb street car... Dunnuck Racing pump gas 440. Best of 10:60@127...
Re: Oil blowing out of breather [Re: frank] #1704020
11/27/14 10:15 PM
11/27/14 10:15 PM
No PCV valve
What do you have for crankcase ventilation? If none at all, just normal blowby will cause your symtoms
Re: Oil blowing out of breather [Re: RapidRobert] #1704021
11/28/14 11:48 AM
11/28/14 11:48 AM
tucson az
frank Offline OP
frank  Offline OP
tucson az
No PCV valve
Just the breather. I cant find a PCV that fits in this valve cover. Engine has 300 miles and runs perfect
Re: Oil blowing out of breather [Re: frank] #1704022
11/28/14 01:15 PM
11/28/14 01:15 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
You must have a PCV system hooked up otherwise you run the risk of blowing out gaskets and it will always leak oil no matter how many breathers you have, imo..
Here's how I did it 25 years ago with cast valve covers. Drilled the right sized hole for the grommet with a hole saw. And bolted in this baffle. I used this valve cover for 20+ years on my car. The baffle worked great.
I learned about PVC valves on my first 340 which came with these cast covers with no PCV hole. They were black and shinny like yours. I fought oil leaks for a while until a mechanic told me it needed it.
So drilled that hole and got a grommet out of a stock valve cover and it stopped my oil leaks and more. Made a difference for the good and I became good friends with that mechanic. You can get that grommet at most "help" sections at auto parts stores. All PCV grommets were the same in those years.
Re: Oil blowing out of breather [Re: QTR MILR] #1704023
11/28/14 04:02 PM
11/28/14 04:02 PM
Alberta
rustbuckett68 Offline
Alberta
Had the same problem in my old van, along with a miss. Compression check showed a dead hole, air pressure blew into the crankcase. Head gasket was iffy, but turned out to be broken rings (about 20 pieces). Only reason I caught it was I noticed some roughness on the edge of the piston where some small pieces left home. Cylinder wall was good. I swore that if I had to do it again, the engine is coming out!
Re: Oil blowing out of breather [Re: Challenger 1] #1704024
11/28/14 04:11 PM
11/28/14 04:11 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
You must have PCV system hooked up otherwise you run the risk of blowing out gaskets and it will always leak oil.
You don't have to have a PCV but it is a good idea for many reasons.
If you don't have a PCV you DO HAVE to HAVE adequate crankcase ventilation though IE: non restrictive breather(s)
All engines develop a certain amount of Blow by. The PCV and or breathers relieve this pressure that would otherwise continue to build up inside the crankcase and eventually begin blowing gaskets seals etc.
If an engine is developing excessive amounts of blowby it is normally due to poor ring seal or a head gasket. A leak down test will establish which of the two is the culprit.
based on your description either your existing breather is very restricted or you have excessive crankcase pressure.
Re: Oil blowing out of breather [Re: frank] #1704025
11/28/14 06:00 PM
11/28/14 06:00 PM
You can buy a rubber grommet that will fit into the valve covers for the PCV valve that will allow you to run another pushin breather cap like your running now, I do that on my race motor running E85 I use two twistin and two pushin breather caps, not the twistin non breather cap like your using now I have a set of those valve covers your using on another street motor I have, I'm using a PCV valve on it If you want I can verify which rubber grommet I used to make the stock Mopar PCV valve fit into those valve covers. I probally have one of those in stock
Re: Oil blowing out of breather [Re: Cab_Burge] #1704026
11/28/14 06:22 PM
11/28/14 06:22 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
Could you please
Appreciate all the information
Re: Oil blowing out of breather [Re: frank] #1704027
11/28/14 07:29 PM
11/28/14 07:29 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I would still encourage a leak down test just to verify the ring seal is good. blowing oil out of a breather cap, especially with baffle in place is usually not a good sign. Leak down testers are relatively inexpensive.
I also would encourage the use of a PCV on a street engine.
Good luck and keep us posted
Re: Oil blowing out of breather [Re: TJP] #1704028
11/28/14 10:28 PM
11/28/14 10:28 PM
Not all machine shops use a torque plate when finishing the final bore preperation, it shouldn't blow the oil out of your motor now as long as you have two breather caps on it, do you?
Re: Oil blowing out of breather [Re: TJP] #1704029
11/28/14 10:54 PM
11/28/14 10:54 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I agree with this as many racers in the older days just used breathers when the cams they used did not pull much vacum and for race engines which are wide open most of the time there is no vacum anyway at wide open throttle so they would use good breathers on their engs and sometimes they used 4 breathers with 2 on each valve cover. I dont use a PCV on the eng in my 63 right now since it does not pull alot of vacum with the cam I use. I use a good breather on each valve cover and it has worked fine for me with this eng. I prefer to use a PCV on a street eng but with a low vacum that big enough cams cause the PCV may not work good. Many racers use the check valves in the header collectors with a hose to the breathers to draw fumes out but on a street car like mine with a full exh system it will not work to well. Course today many serious racers making alot of power use a vacum pump to create a vacum in the crankcase and pick up some extra hp. But I agree that most street engines pull enough vacum and can use a PCV system which they should. You should be able to do like some on here said and find a gromett to fit one of your valve covers to hook a PCV valve in. Ron
Re: Oil blowing out of breather [Re: frank] #1704030
11/28/14 11:07 PM
11/28/14 11:07 PM
OT but for reference it is a good read on ring seal. "breakin secrets" at www.mototuneusa.com
Re: Oil blowing out of breather [Re: Cab_Burge] #1704031
11/28/14 11:16 PM
11/28/14 11:16 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
No only one breather. Torque plate was used on this engine. The break in was done on the dyno. I didn't use a PCV because I could not find one to fit these MP valve covers.
Re: Oil blowing out of breather [Re: RapidRobert] #1704032
11/28/14 11:24 PM
11/28/14 11:24 PM
Cincinnati, Ohio
Cincinnati, Ohio
I have never read the entire link, it's a good one. But I think your saying? or they are saying a PCV will help the rings seat better just like a vacuum pump on a much smaller scale?
Either way that's my opinion for a street car, that a PCV valve will help the rings.
Re: Oil blowing out of breather [Re: frank] #1704033
11/28/14 11:30 PM
11/28/14 11:30 PM
Cincinnati, Ohio
Cincinnati, Ohio
Can you post a picture of the passenger side valve cover?
