8 3/4 yoke #1703807
11/27/14 11:21 AM
11/27/14 11:21 AM
Canada
Dons Dart Offline OP
Canada
Was wondering why did they make an 8 3/4 with the big and Small yoke? what are the pros and cons.
Re: 8 3/4 yoke [Re: Dons Dart] #1703808
11/27/14 11:28 AM
11/27/14 11:28 AM
Maryland
gofastboater Offline
Maryland
Because they could. Bigger is better.
Re: 8 3/4 yoke [Re: gofastboater] #1703809
11/27/14 11:42 AM
11/27/14 11:42 AM
Canada
Canada
Thanks.,so i just bought the 8 3/4 with the small one should i be conserend with standing on it?
Re: 8 3/4 yoke [Re: Dons Dart] #1703810
11/27/14 11:42 AM
11/27/14 11:42 AM
Canada
Canada
Thanks.,so i just bought the 8 3/4 489 with the small one should i be conserend with standing on it?
Re: 8 3/4 yoke [Re: Dons Dart] #1703811
11/27/14 12:10 PM
11/27/14 12:10 PM
wilmington,ohio
O
ohiodemon Offline
ohiodemon  Offline
O
wilmington,ohio
i think the larger yokes were used in big block and large body cars.
Re: 8 3/4 yoke [Re: ohiodemon] #1703812
11/27/14 01:06 PM
11/27/14 01:06 PM
scratchnfotraction Offline
correct.
my 67 8 3/4 polara has the large 1330 yoke and was only on 426/440HP cars.
I have stomped on many small 7260 yokes/joints from cars to 4x4 and never had any break..u-joints wear out and fail but never broke a yoke.
unless you are high HP with sticky tires your good to go.IMHO.
Re: 8 3/4 yoke [Re: scratchnfotraction] #1703813
11/27/14 01:57 PM
11/27/14 01:57 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
My 65 B body factory 361 with 4 speed had the small joint.I popped a few till I found the yoke was bad.Replaced it about 30 years ago with a good small yoke and its still alive with the built 440.My Imps did have the big joints.When I go Dana Ill go large joint only because I have to change the drive shaft.Rocky
Chrysler Firepower
Re: 8 3/4 yoke [Re: Dons Dart] #1703814
11/27/14 02:36 PM
11/27/14 02:36 PM
You'll be fine. Just get a good made in USA brand & after installation make SURE it moves free back & forth by hand (rear ujoint) and front ujoint/trans yoke moves free back & forth in both planes. If it dont, whack the ears till it does
Re: 8 3/4 yoke [Re: RapidRobert] #1703815
11/27/14 03:28 PM
11/27/14 03:28 PM
Canada
Canada
Thanks guy happy turkey day.
Re: 8 3/4 yoke [Re: Dons Dart] #1703816
11/27/14 04:58 PM
11/27/14 04:58 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Max Wedge and '64-'65 Hemi cars had the small yoke.
Re: 8 3/4 yoke [Re: scratchnfotraction] #1703817
11/27/14 06:17 PM
11/27/14 06:17 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
correct.
Disagree, The 340 small block 68-9 darts had the bigger joints as did many other applications.
Why?? because they were stronger. But I will agree the small joints will take a lot of abuse
Re: 8 3/4 yoke [Re: Dons Dart] #1703818
11/27/14 07:25 PM
11/27/14 07:25 PM
Cab_Burge Online work
Cab_Burge  Online Work
The only true answer is probally in Mopar decision makers corrosponces All the early cars, 1963 and earlier had the 7260 rear joints, ball and trunion front joints of severl difference sizes Once the 5 year 50,000 mile warrenty was started in 1962 or 1963 it probally made since to make parts stronger, especially with the HP wars, race on Sunday, sell on Monday and pony car wars started. The beefeir parts where probally put on the cars so they wouldn't have to replace them under warrenty and pay the dealers shop mechanics to fix them, as well as seeing cars break parts at the track wasn't good advertising either
Re: 8 3/4 yoke [Re: Cab_Burge] #1703819
11/27/14 09:40 PM
11/27/14 09:40 PM
Canada
Canada
Great info boys,this 489 surgrip 323 gear has the small yoke the seller has told me,i should be delivered tomorrow.I all ready have the 489 with 323 not suregrip,i have to admit i have no clue what yoke it is,the old 7 1/4 witch was in the car that joint bolted right on.
Re: 8 3/4 yoke [Re: Dons Dart] #1703820
11/27/14 09:49 PM
11/27/14 09:49 PM
okla.
sam64 Offline
sam64  Offline
okla.
I had the small ujoints in my 10.80's @123 3300lb 63 belvedere,mid 1.50 60fts on 29.5x9x15 m/t slicks.i put a dana 60 in it last winter and went to 1350 yokes and it hasn't been on the track since.
Re: 8 3/4 yoke [Re: Dons Dart] #1703821
11/27/14 10:11 PM
11/27/14 10:11 PM
This 489 surgrip 323 gear has the small yoke should be delivered tomorrow.I all ready have the 489 with 323 not suregrip,i have to admit i have no clue what yoke it is,the old 7 1/4 witch was in the car that joint bolted right on.
likely 7260 on the 7&1/4. You may not even need a ujoint change. You'll know tomorrow
