70 E body aftermarket air cond question
#1703645
11/26/14 08:33 PM
11/26/14 08:33 PM
Posts: 1,894 N of Detroit
DaveDudek
N of Detroit
Hello, Working on a 70 Challenger 318 w/ factory air. Were installing a warmed up 340 in her and we still want the air conditioning. What's the best kit out there? I want something nice and neat.
Dave Dudek 1st Factory Stock legal car in the 10`s!!! [/b] FAST & Factory Stock Rules: www.fastraces.org FAST 69 Hemi RR 9.98@139
Re: 70 E body aftermarket air cond question
[Re: stumpy]
#1703647
11/26/14 08:47 PM
11/26/14 08:47 PM
DaveDudek
N of Detroit
I don't have a whole lot of experience with air condition cars. I'm assuming that they're pretty inefficient? If that's all everyone's doing I'll put a new style compressor on. Is there a part number handy?
[Re: RSNOMO]
#1703650
11/26/14 08:51 PM
11/26/14 08:51 PM
Posts: 4,744 Florida
BDW
I used a Vintage Air bracket, you can get it from Summit http://i909.photobucket.com/albums/ac294/sublime/Car/AC/Challey_AC.jpg I used a Sanden 4471 Compressor I got on Ebay. You can also go to Sanden website and compare all the specs if you find another model. There are MANY choices, but I found a great deal for only $115. The Chineses knock-offs usually sell for $175, and the real Sandens go for $250 or more. http://www.sanden.com/index.php?productsearch You will need to splice in the electrical connector, that's the main difference between most of the compressors.
[Re: Fern]
#1703653
11/26/14 10:14 PM
11/26/14 10:14 PM
Posts: 103 M.A.
Fern
M.A.
[Re: DaveDudek]
#1703654
11/26/14 10:28 PM
11/26/14 10:28 PM
Posts: 12,210 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
My experience is with big block systems, but the new systems work really well. They throw out very cold air. Bouchillon, Vintage Air, and Classic Air (and maybe others) make kits for these cars. Every kit has it's pluses and minuses. Look them over and see what you like about them and get the pieces that puts the system in the way you like.
The 2 complaints I hear the most is that guys don't like the empty rear belt groove (looks like something is missing). And the way that the hoses leave the compressor. Again, that is on big blocks. You can get the hoses and ends separate and have them crimped by a hose repair place near home if you don't like the way the kits come.
Lots of choices. Unusual for us Mopar guys.
Master, again and still
[Re: scatpacktom]
#1703660
11/28/14 09:45 AM
11/28/14 09:45 AM
BDW
I can't think of a reason not to use the orig parts
Something about the "new" compressor makes me want to
I used as much of the original parts as possible. Original evaporators are larger than aftermarket kits.
But the new compressor is a must, 15lbs lighter, more efficient and you use the R134 freon. Cost would be crazy with R12 if you have to do it a couple of times to fix leaks.
[Re: DaveDudek]
#1703661
11/28/14 04:51 PM
11/28/14 04:51 PM
Posts: 464 KY
Telvis
KY
I swapped the old iron compressor for the Buchillon sanden setup and love it. It cools much better to me. It's easy to do and not too bad cost wise. Probably one of the best upgrades I have done to my car
That's King Weenie to you!
