roller cam choice #1703618
11/26/14 06:08 PM
11/26/14 06:08 PM
Virginia Beach, VA
O
Old School Offline OP
O
Virginia Beach, VA
on one of my 500" motors, I spun the cam bearings and bent the cam. i'm rebuilding the motor now. my cam spec is: comp roller 272/276 @.050 .649" with 1.6 rockers. 108 centerline. I run this same cam in 3 other motors. all street cars.
question is, I have a spare cam that specs:cmi roller 276/283 @.050 .737"/.672" with 1.6 rockers. 107/115 centerline. to use this cam instead of buying a new one, would be nice. would this cam be to aggressive for a street car?
motor specs: 500"
sr 295
13.1
indy dualplane
1000 ho AED CARB
with the old cam, the motor made 700 hp. not really looking for more power, just would like to use this old cam....
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: roller cam choice [Re: Old School] #1703619
11/26/14 07:21 PM
11/26/14 07:21 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
If you liked the old one, I'd run it. Sounds like a pretty wild street motor anyway. Intake duration isn't much larger. LCA is 111, pretty wide at that duration. What was the LCA of the old cam?
Doug
Re: roller cam choice [Re: Old School] #1703620
11/27/14 12:36 AM
11/27/14 12:36 AM
Comp can fix that cam, I've had several roller lifters fail on the same cam two different times and Comp fix it both times real well I would call them to get a return authorization number and send it in to see if it is fixable
Re: roller cam choice [Re: Cab_Burge] #1703621
11/27/14 09:15 AM
11/27/14 09:15 AM
pa
572charger Offline
572charger  Offline
pa
id run that cam then put a fogger or a plate on it
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: roller cam choice [Re: 572charger] #1703622
11/27/14 10:26 AM
11/27/14 10:26 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
Sounds like na old cam motion grind, I blieve Indy sells them now. A healthy lift! I have used that cam in a couple of build ups in a 3.75 and 4.15 stroke street engines. With the longer stroke it was very versatile, making even ecent low end tq. And I had less CR than you, a pump gas engine.
Plynouth VIP '67 TT IC EFI
Re: roller cam choice [Re: Old School] #1703623
11/27/14 02:37 PM
11/27/14 02:37 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`ve got less lift but 276-281 @ .050 and have driven my 470 all over and no issues except maybe gas mileage.............
Re: roller cam choice [Re: Old School] #1703624
11/28/14 12:13 PM
11/28/14 12:13 PM
NC
440Jim Offline
440Jim  Offline
NC
motor specs: 500"
sr 295
13.1
indy dualplane
1000 ho AED CARB
From what you posted, that cam will be fine. You have enough CR to run it. The only thing, the cam will be harder on the valve train (springs, etc.). Also, check to make sure your intake spring setup can accommadate that much lift with the 1.6 rockers.
When you say 107/115 centerline, do you mean you install it with the intake lobe center at 107 ATC and the exhaust lobe center at 115 BTC? ie. 111 lobe separation angle (LSA)
