Engine Storage Cradle Recommendation Wanted #1703579
11/26/14 05:18 PM
11/26/14 05:18 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Anyone have or used the Summit brand engine cradle? I may be taking a road trip over the Thanksgiving Holiday to pick-up a 340 engine. I was planning to purchase a 1" box steel cradle. I never used the Summit brand, but I was concerned the front attachment on the Summit model did not have any bolt attachments just resting points. Reference attachment.
Any feedback or other recommendations on steel cradles would be greatly appreciated.
Thank you in advance and Happy Thanksgiving to you and your family!
Vinny
Re: Engine Storage Cradle Recommendation Wanted [Re: vinnyd76] #1703580
11/26/14 06:45 PM
11/26/14 06:45 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
A ratchet strap will fix the "problem" with the Summit cradle. How does the allstar brand mount up front? thru the motor mounts? Timing chain cover bolt holes?
Don't be the exception.
Re: Engine Storage Cradle Recommendation Wanted [Re: vinnyd76] #1703581
11/26/14 06:56 PM
11/26/14 06:56 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
The cradle/dolly andyF and the one ones I used to make are much better than those flimsy summit/all star non-fitting on a mopar engine product. I don't think either of us build them anymore.
Last one I saw needed some grinding mods to work on a SB.
Do they work, yes (sort of), are they cheap in price, materials and design, yes.
Re: Engine Storage Cradle Recommendation Wanted [Re: RobX4406] #1703582
11/26/14 07:14 PM
11/26/14 07:14 PM
Annapolis, MD, USA
V
Vert Offline
Vert  Offline
V
Annapolis, MD, USA
I bought one of Andy's thru Mancini Racing a little over a year ago. Mine was for a big block tho. I'd love to see a version that converts into a runstand. I thought it was a little pricey, but it is high quality. And so many of us are CHEAP. :-)
Re: Engine Storage Cradle Recommendation Wanted [Re: Vert] #1703583
11/26/14 08:21 PM
11/26/14 08:21 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Free=old tire
Cheap = HD furniture dolly from various sources
+ a couple short sections of 2X4 and a pair of straps, one to hold engine on dolly, one to hold in place. You can replace the dolly with a small pallet if desired. The dolly is useful once it gets home, unless you have a pallet jack.
Re: Engine Storage Cradle Recommendation Wanted [Re: RodStRace] #1703584
11/26/14 08:44 PM
11/26/14 08:44 PM
NoVa
E
ebodyseast Offline
ebodyseast  Offline
E
NoVa
I built one years ago for B engine using (4) 2X6s, (4) angle irons and 4 wheels from Lowe's/Home Depot. The length of the oil pan rests on two of the upright 2x6s. Notched the back end corners for clearing the flexplate.
Re: Engine Storage Cradle Recommendation Wanted [Re: Vert] #1703585
11/26/14 08:50 PM
11/26/14 08:50 PM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
Build your own out of 2 x 6's or 2 x 8's. It's easy, works great and cheap! Add casters and it's easily mobile!!!!!
Admiration For Multiple Carburetor Vehicles...
Re: Engine Storage Cradle Recommendation Wanted [Re: Stewpar] #1703586
11/26/14 08:51 PM
11/26/14 08:51 PM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
Re: Engine Storage Cradle Recommendation Wanted [Re: Stewpar] #1703587
11/26/14 11:48 PM
11/26/14 11:48 PM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
I just made a transport cradle for my 340 using plans from this thread last weekend. Very easy to do and should serve the purpose. I sat mine on a small HF dolly to move it around my garage.
http://www.forabodiesonly.com/mopar/showthread.php?t=256797
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
