Re: 2003 Durango tranny doesn't have 1st gear anymore?
[Re: MN-ScatPack]
#1703249
11/25/14 08:30 PM
11/25/14 08:30 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Witch engine/trans?
If it is a 5.9 then it is a 46re and may need the rear band adjusted or replaced or something to do with actuating it is bad.
If it is a 4.7 buy a JY trans they are cheap because the engines are so terrible and the trannys are pretty reliable.
[Re: MN-ScatPack]
#1703250
11/25/14 08:31 PM
11/25/14 08:31 PM
HotRodDave
Kalispell Mt.
I have also seen the OD unit itself go bad and cause no reverse or OD.
[Re: MN-ScatPack]
#1703252
11/25/14 08:49 PM
11/25/14 08:49 PM
HotRodDave
Kalispell Mt.
Sorry, nothing I said applies to that trans. I have never been into one of them because they are so cheap and plentiful to just replace. Been into tons of the 46RE though.
[Re: ademon]
#1703255
11/26/14 12:29 AM
11/26/14 12:29 AM
Posts: 1,822 Colorado
denfireguy
Colorado
You might as well not even change the trans that's how bad the 4.7 is. How does the fluid look and smell?
Sorry, my 2003 4.7L Durango AWD is still going strong at 190,000. Other than plugs (twice) and oil changes, the engine has never been touched. Thanks, Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: denfireguy]
#1703256
11/26/14 12:39 AM
11/26/14 12:39 AM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
Just being a rascal! My 03 Dakota has 216k, these engines were in a LOT of Dakota, Durango, Rams, jeeps etc.. My local CL right now has 4 running 4,7's for sale from JY's with warranty.
[Re: gtx6970]
#1703257
11/26/14 01:35 AM
11/26/14 01:35 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
that will be a 45rfe . drop the pan and see if the side cover plate blew off the side of the valve body ( common issue )
Yes I would do this first as I saw that happen alot at the Dodge dealer I worked at. Ron
[Re: HotRodDave]
#1703258
11/26/14 05:20 AM
11/26/14 05:20 AM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
Witch engine/trans?
The rear band isn't even applied for first gear when the shifter is in drive and wouldn't have anything to do with the trans slipping on takeoff. In a 46RE, in DRIVE, 1ST gear is the rear clutch is applied, the over-running clutch (sprag) holds, and the direct clutch is applied. In MANUAL LOW the rear band is also applied to provide engine braking.
Slipping on take-off in a 46RE (in drive) is usually the rear clutch or the O/D direct clutch. If it only slips in drive, but NOT reverse, it's usually the rear clutch. Slips in both, probably the O/D direct clutch.
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: Evil Spirit]
#1703260
11/26/14 09:51 PM
11/26/14 09:51 PM
383man
Balt. Md
Witch engine/trans?
From what I remember you could have the O/D clutch slip in the O/D unit in reverse but not in drive as I had this once. The O/D unit has an overrunning clutch that will hold in drive if the O/D clutches are worn. It will slip in reverse since of course the overrunning clutch will not work in reverse. I was told the reason for the overrunning clutch in the O/D unit is so there is no rpm flare when it shifts from drive (3rd gear) to overdrive as it holds the shaft as the direct clutches release and the O/D clutches apply. I had a tech have this happen when he put the wrong number of clutches in the direct clutch pack as it would slip in reverse if on a slight hill but no problem in drive. He forgot to read a TSB about when they made changes and added a clutch plate to the direct clutch and he did not count how many were in it when he took it apart. Ron
