Not a Challenger, but on my '85 D150 ... which fits from the early '70s on up, and also fits passenger cars.
A while back I thought I had a problem with my ts switch, bought a ebay Standard brand, TW4 I think. Thinking was, name brand, might be USA made.
Thought I cured my problems without using the switch, and put it away where I could find it. You know where this is going, right?
Soooo, when I needed it to get the brake lights working, I couldn't find it, and bought another ebay one, this one un branded.
Before it got here, I found the first one, so when the 2nd one got here I compared them.
Both made in Taiwan, identical to each other, and at replacement time they had same color codes and even the same color plug as the factory one I took out.
And everything is working now, I are a happy camper.
Is it possible you got one for a tilt column? Tilts were Saginaw, used different components.
