Waterpump Pulley???? #1702973
11/24/14 07:53 PM
11/24/14 07:53 PM
Phoenix,Az.
hemicop Offline OP
hemicop  Offline OP
Phoenix,Az.
HELP! I need a 5in waterpump pulley for my Hemi. Anyone have a part number or source for such a thing?
Re: Waterpump Pulley???? [Re: hemicop] #1702974
11/24/14 07:56 PM
11/24/14 07:56 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
See if this would work.
http://store.440source.com/Billet-Aluminum-Pulleys/products/136/
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Waterpump Pulley???? [Re: pittsburghracer] #1702975
11/26/14 05:08 PM
11/26/14 05:08 PM
Phoenix,Az.
hemicop Offline OP
hemicop  Offline OP
Phoenix,Az.
Thanks! But it's too big.
Maybe I'm looking at this wrong. My crank pulley is 6ins. & the water pump pulley is 6.6/7ins. What were the stock Hemi pulleys? Anyone have an idea for pulleys on an 830hp hemi? The guys from Griffin tell me the radiator/fan shroud combo should cool it & that the problem is the coolant is possibly going through the engine too fast---or perhaps too slow. They said usually the crank pulley is larger than the pump one, so I'm wondering if It's all just backwards.
Re: Waterpump Pulley???? [Re: hemicop] #1702976
11/26/14 06:22 PM
11/26/14 06:22 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
A lot depends on whether you're using a 6-vane pump or an 8-vane pump. From the factory the 6-vane was driven at 140% of crank speed, the 8-vane was underdriven at about 90% of crank speed.
Re: Waterpump Pulley???? [Re: John_Kunkel] #1702977
11/27/14 02:24 PM
11/27/14 02:24 PM
Phoenix,Az.
hemicop Offline OP
hemicop  Offline OP
Phoenix,Az.
Thanks! Now I'm getting somewhere. Is the Milodon "HD" pump 6 or 8 vane?
Re: Waterpump Pulley???? [Re: hemicop] #1702978
11/28/14 01:55 PM
11/28/14 01:55 PM
IN
ahy Offline
ahy  Offline
IN
What has worked well for me (496 B) is an older MP high volume pump slightly overdriven (6.25" crank pulley, ~5.75 WP pulley). Cools great including AC. Bouchillon has a good selection of pulleys. That's where I got mine. The MP pump is no longer sold. The Milodon may be OK with correct drive and Mancini sells their own brand high volume pump as well.
I'd start with the pulley.
Re: Waterpump Pulley???? [Re: ahy] #1702979
11/28/14 07:15 PM
11/28/14 07:15 PM
Phoenix,Az.
hemicop Offline OP
hemicop  Offline OP
Phoenix,Az.
Thanks! I'll have to check with them.....
